GSR XFP and SIP/SPA question
Jaypal_pande
Hi Guys,
I have couple questions regarding GSR XR 12000.
1) can I use XFP (XFP-10GLR-OC192SR - Multirate XFP module for 10GBASE-LR and OC192 SR-1) on a 10G LAN PHY SPA (SPA-1X10GE-L-V2 - Cisco 1-Port 10GE LAN-PHY Shared Port Adapter) ? From the dynamic configuration tool it seems that it can support STM64/10G WAN PHY and LAN PHY. I just need a confirmation.
2) For SIP-601 I tried to put together SPA-1X10GE-WL-V2 and SPA-OC192POS-XFP, but it gives me the error. Is there a reason these cards cannot run together in the same SIP-601. I have tried configuration for two of the same kind and it works.
Best reagrds and thanks.
Frederic Vanderbecq
you can find the datasheet for all the supported XFP for the SPA-1X10GE-L-V2 at the following URL:
http://www.cisco.com/en/US/prod/collateral/modules/ps6267/product_data_sheet0900aecd804dc62d.html
For the second problem, which error do you get when inserting both SPA-1X10GE-WL-V2 and SPA-OC192POS-XFP at the same time ?
Best regards
