Cisco ASA - Can't get through NAT
raresz
Hi. I have cisco ASA with 4 vlans (DMZ, inside, outside, WiFi - unused). I have also NextCloud server in my DMZ vlan which i want to be accessible from outside. I managed that on Cisco Router but i'm fresh with Cisco ASA. I tried to do it how official Cisco documentation says:
Cisco documentation
and i checked lot of other pages. And it just doesn't work.
NextCloud is 192.168.2.3
First i tried with command :
Czernobyl(config)# object network nextcloud_public
Czernobyl(config-network-object)# host A.B.C.D(my hidden public IP)
Czernobyl(config-network-object)# exit
Czernobyl(config)# object network nextcloud_private
Czernobyl(config-network-object)# host 192.168.2.3
Czernobyl(config-network-object)# nat (DMZ,outside) static nextcloud_public service tcp 443 443
ERROR: Address A.B.C.D overlaps with outside interface address.
ERROR: NAT Policy is not downloaded
So i have used "interface" keyword to workaround that - it has accepted the command, i applied some ACL and finally still doesn't work. Here are my outputs:
#show version
Spoiler
Device Manager Version 7.9(2)152
Compiled on Wed 13-Mar-13 07:45 by builders
System image file is "disk0:/asa911-4-k8.bin"
Config file at boot was "startup-config"
Czernobyl up 42 mins 53 secs
Hardware: ASA5505, 512 MB RAM, CPU Geode 500 MHz,
Internal ATA Compact Flash, 128MB
# show nat
Spoiler
Czernobyl# show nat
Manual NAT Policies (Section 1)
1 (DMZ) to (outside) source dynamic obj_any interface
translate_hits = 24, untranslate_hits = 0
Auto NAT Policies (Section 2)
1 (DMZ) to (outside) source static nextcloud interface service tcp https https
translate_hits = 0, untranslate_hits = 0
2 (inside) to (outside) source dynamic obj_any interface
translate_hits = 811, untranslate_hits = 3
#show running-config
Spoiler
ASA Version 9.1(1)4
hostname Czernobyl
domain-name raresz.local
enable password qguZBuP5aUM4/9xH encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
switchport trunk allowed vlan 1,20
interface Ethernet0/3
interface Ethernet0/4
switchport access vlan 12
interface Ethernet0/5
interface Ethernet0/6
switchport access vlan 4
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address dhcp setroute
interface Vlan4
nameif WiFi
security-level 100
ip address 192.168.4.1 255.255.255.0
interface Vlan12
nameif DMZ
ip address 192.168.2.1 255.255.255.0
ftp mode passive
clock timezone EEST 2
clock summer-time EEDT recurring last Sun Mar 3:00 last Sun Oct 4:00
dns server-group DefaultDNS
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network obj_any
subnet 0.0.0.0 0.0.0.0
host A.B.C.D
host 192.168.2.3
host 192.168.2.3
access-list outside_acl extended permit tcp any object nextcloud eq https
access-list outside_acl2 extended permit tcp any host A.B.C.D eq https
pager lines 24
logging enable
logging timestamp
logging buffer-size 16762
logging monitor warnings
logging trap notifications
logging asdm errors
logging facility 23
logging host DMZ 192.168.2.4 6/1470
logging flash-bufferwrap
logging permit-hostdown
mtu inside 1500
mtu outside 1500
mtu WiFi 1500
mtu DMZ 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
nat (DMZ,outside) source dynamic obj_any interface
nat (inside,outside) dynamic interface
nat (DMZ,outside) static interface service tcp https https
access-group outside_acl2 in interface outside
router ospf 1
network 192.168.1.0 255.255.255.0 area 0
network 192.168.2.0 255.255.255.0 area 0
network 192.168.4.0 255.255.255.0 area 0
area 0
log-adj-changes
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
http server enable 8443
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ca trustpool policy
telnet timeout 5
ssh 192.168.1.0 255.255.255.0 inside
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.1.5-192.168.1.254 inside
dhcpd option 43 ip 10.20.0.2 interface inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ntp server 95.216.71.38 source outside prefer
ssl encryption 3des-sha1 aes128-sha1
webvpn
anyconnect-essentials
class-map inspection_default
match default-inspection-traffic
Anybody has any ideas?
Hello
lol apologies i posted the wrong nat statement is was meant to state
no nat (DMZ,outside) source dynamic obj_any interface
nat (DMZ,outside) static interface service tcp https https (already applied)
Kind Regards
Paul
7 Replies 7
Hello
try making the following changes:
No nat (inside,outside) dynamic interface object network nextcloud
Kind Regards
Paul
raresz
I don't get it. There is nowhere mentioned about DMZ. I mean "inside" is my local vlan where i keep private devices. Nextcloud is in DMZ vlan.
Hello
Kind Regards
Paul
Ok. works. But... Does that mean now - rest of clients in DMZ will have no internet access, yes? Can i get something what would make it both work?
I don't know why i always have a problems with NAT...On the c2800 i had also problem with that : or it was working static PAT only or only overload. It took me about 3 days to manage it and finally i have no idea what was wrong because it has fixed by itself after some hour of doing nothing (please dont ask i really dont know how it happened :D)
If i now apply there statement of dynamic nat somehow it will combine together and will work overload and static PAT?
Hello
You can be more specific
object network web-public
host <public ip address>
nat (DMZ,outside) static web-public service tcp https https
object network dmz-lan
range 192.168.2.4 192,168.2.254  (note: static dmz host not included)
nat (DMZ,outside) dynamic interface
Kind Regards
Paul
Asemmoqbel
Dear Raresz,
Allow me to explain a little about Nat rules priorities on ASA.
There are three nat types:
1- Manual Nat.
it's first prioritized  and preferred over other nat rules. It's displayed under Section 1 on "Show nat"
2- Auto Nat
it's second prioritized and preferred after Manual. these nat rules are created within Objects and it's displayed under Section 2 on "Show nat"
3- Manual Nat with "after-auto" keyword
it's last prioritized. it's displayed under Section 3 on "Show nat"
Also, in Auto-Nat rules there are prioritization as following:
- Static is prioritized and preferred  over Dynamic.
- more specific real IP
In your configurations, you can apply two auto-nat rules
1- auto-nat for static PAT for nextcloud server
Object Network Nextcloud-PAT
host 192.168.2.3
Nat(dmz,outisde) static interface service tcp https https
2- Auto-nat for dynamic PAT for DMZ subnet
Object Network DMZ-Pat
subnet 192.168.2.0 255.255.255.0
Nat (Dmz,outside) dynamic interface
with the above rules, the static rule will be prioritized first and then the dynmaic will take effect. you can confirm this by issuing "show Nat" and you will see the static rule is placed before dynamic one..
Best Regards
Asem ..
Ok  thanks guys for a proper answers. Will be fighting with that soon. I wish only Cisco ASA had same cli like IOS on routers...the thing is i don't really want to learn ASA logic too much because i'm preparing for CCNA exam so that would really harm my mind. I just want to focus on router/switch IOS for now. Anyway thanks a lot!
