08-15-2006 10:42 PM - edited 03-03-2019 01:40 PM
Hi guys,
I need your experience on this issue
Setup:
-WAN-[CISCO ASA]--LAN
...----DMZ------...
.routerA....router B....
DMZ IP: 192.1.1.1
Router A: 192.1.1.10
Router B: 192.1.1.12
Router A and Router B are local routers which will communicate with remote routers.
Applications behind RouterA use 10.100.2.55 address
Applications behind RouterB use 172.10.10.4 address
I have create routes for my LAN traffic to access the application address using the Router as gateway respectively.
Strangely, i can ping and access 172.10.10.4 but not 10.100.2.55.
I do not know where to troubleshoot as route configuration are similar.
Iwan
08-30-2006 11:25 PM
It would be tough to see the routes after RouterA as these are beyond the company's entity.
12-14-2018 09:09 PM - edited 12-26-2018 08:30 PM
The ASA in Cisco ASA stands for Adaptive Security Appliance. In brief, Cisco ASA is a security device that combines firewall, antivirus, intrusion prevention, and virtual private network (VPN) capabilities.
