Cisco ASA5515 Feature
Support ACME
Dear ALL,
Our company have 2 x ISP internet broadband,  we want to use the CISCO ASA 5515-X iwth FirePower to replace our Juniper SSG140.
We would like to know the ASA 5515-X can fulfil the bewlow requirment.
1. Outbound Multiple Internet Connections by Traffic balancing(it means when one of link 70% utilization, it can auto switch to second link)
Remark: if yes, please give us more information.
2.  High Availability
3. Detect and Disable suspicious traffic.
Support
Philip D'Ath
1. No
2. Yes - if you want to handle a firewall failing you need a pair of them.
3. Yes - using fFirepower in particular.
You will need a Cisco router to do (1) nicely.
Dear Philip D'Ath,
Thanks for your reply.
TungHo
