Cisco ASR 1004 - Bridge-group command missing.
adil.nasser3
On the Cisco forums, an example is shown for how to  configure BVI and bridge-groups on an ASR1004 but the same command  (bridge-group) is not available under the interface on our ASR routers.  Can someone tell us why?  We are running version of code:
asr1000rp1-advipservicesk9.03.06.00.S.152-2.S.bin
From the CISCO FORUMS:
problem with bvi interface on ASR  1004
I tried to  use bvi interface on ASR 1004 but it wasnot successfull..
What should be the problem:
ASR learns mac  address. but it does not ping the devices. But if i assign the same ip to  phisical port, it works (PINGS..)
asr 1000 e ait  bridging config guide da bulamadim.
bridge irb
bridge 1 route  ip
bridge 1 protocol ieee
interface GigabitEthernet0/0/1
description 6500-BACKBONE-1
no ip address
negotiation auto
bridge-group 1
interface GigabitEthernet0/0/2
description  6500-BACKBONE-2
no ip address
shutdown
negotiation auto
bridge-group 1
interface BVI1
ip address 10.72.33.250  255.255.255.
OUR ASR is missing the command (see below):
nuspth-1208-000-wwr0(config)#int gi0/0/2
nuspth-1208-000-wwr0(config-if)#?
Interface configuration commands:
aaa                 Authentication, Authorization and  Accounting.
access-expression   Build a  bridge boolean access expression
analysis-module     Configure NAM on the interface
arp                 Set arp type (arpa, probe, snap), timeout,  log options or packet priority
backup               Modify backup parameters
bandwidth           Set bandwidth informational parameter
bfd                 BFD interface configuration  commands
bgp-policy          Apply  policy propagated by bgp community string
carrier-delay       Specify delay for interface  transitions
cdp                 CDP  interface subcommands
channel-group        Add this interface to an Etherchannel group
Bridging is not supported on ASR1000. ASR can still accept the command but it will not take effect. The feature is not supported on this platform. You can alternatively use BDIs
http://www.cisco.com/en/US/docs/routers/asr1000/configuration/guide/chassis/bdi.html
-Karthic
