[Split DNS] - Views and domain names
Vivien FRANCOIS
I implement a basic split DNS in my router : a default view wiht my parameters (forwarding source interface...).
What I need to do is have another view which will be applied only when computers in the network will try to access *.mydomain.com (for example). If the DNS request does not concern *.mydomain.com it will use the default view parameters.
Is there a way to do that with split DNS ?
Thanks in advance.
V.
That's what SplitDNS is for. Here is an example:
! specify which domain needs extra handling:
ip dns name-list 1 permit \.company\.local
! where to send the specially handled domains:
ip dns view COMPANY
logging
dns forwarder 10.11.12.13
dns forwarding source-interface Vlan254
! your default-handling:
ip dns view default
logging
domain timeout 2
dns forwarder 8.8.8.8
! here the two settings are combined in the right order and applied to the router:
ip dns view-list DNS
view COMPANY 10
  restrict name-group 1
view default 1000
ip dns server view-group DNS
ip dns view COMPANY
logging
ip dns view default
logging
domain timeout 2
view COMPANY 10
view default 1000
HI,
Thanks a lot. It works perfectly.
Have a good day.
V.
