Bookmark
Subscribe
976
Cisco ASR 1004 & SFP-GE-T Problem
hamza.khaida
We have a Cisco ASR1004 with SPA-8X1GE-V2 SPA. When we insert an SFP-GE-T in the SPA, the link fails to become active. The LEDs are amber in  color and the interfaces status is down down. The ASR  is directly connected to a Cisco 2960 switch. We have verified cables  are good and ports on the switch are good as well. We have tried to set  port speed/duplex, nonegoiate auto etc on both ends to no avail.
RT-HQ#show hw-module subslot 0/0 transceiver 6  idprom
IDPROM for transceiver GigabitEthernet0/0/6:
  Description                                    = SFP optics (type 3)
  Transceiver Type:                         = GE T (26)
  Product Identifier (PID)                 = N/A
  Vendor Revision                            = 11
  Serial Number (SN)                       = MTC1231008M
  Vendor Name                                = CISCO-FINISAR
  Vendor OUI (IEEE company ID)    = 20.20.20 (2105376)
  CLEI code                                      = N/A
  Cisco part number                         = N/A
  Device State                                  = Enabled.
  Date code (yy/mm/dd)                   = 13/03/04
  Connector type                              = LC.
  Encoding                                       = 8B10B
  NRZ
  Nominal bitrate                            = GE (1300 Mbits/s)
  Minimum bit rate as % of nominal bit rate = not specified
  Maximum bit rate as % of nominal bit rate = not specified
Giuseppe Larosa
Hello Hamza,
the issue is with the version of the SFP this has been reported several times here in the forums
Hope to help
Giuseppe
