MPLS on Supervisor2T, Catalyst 6500,15.1.1SY
k.lapczuk
Hi Guys,
I'm trying to configure QoS on 10G L3 MPLS interfaces in 6500 with Sup2T. I need a simple thing - EXP bits should be preserved on Egress from
ingress MPLS frames. I've found that it should work like this by default, but in my case EXP bits are always reset to 000. Is there any good config to do this thing?
Best regards,
Krzysztof
Giuseppe Larosa
Hello Krzysztof,
see
EXP Mutation
You can configure up to eight egress EXP mutation maps to mutate the  internal EXP value before it is written as the egress EXP value. You can  attach egress EXP mutation maps to these interface types:
LAN port subinterfaces
Layer 3 VLAN interfaces
Layer 3 LAN ports
You cannot attach EXP mutation maps to Layer 2 LAN ports (ports configured with the switchport command).
For configuration information, see the"Configuring MPLS QoS Egress EXP Mutation" section.
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/15.1SY/config_guide/sup2T/mplsqos.html#wp1481775
Hope to help
Giuseppe
