05-18-2015 03:03 AM - edited 03-05-2019 06:55 AM
Hello all,
I have Cisco ASR 1004 and i would upgrade IOS. Can I follow standard procedure (download IOS, change bootvar and reload)? Or I have to enable sso redundancy?
Thanks in advance
05-18-2015 04:51 AM
You can follow standard procedure with a reload.
05-18-2015 04:55 AM
Thanks Bilal. I will let you know.
05-18-2015 05:56 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Yes, you might be able to follow typical router IOS upgrade procedures, but with the ASR series, you might check whether the IOS has been split into components (or whether you wish to do so). Component based IOS implementations add a new step to the process.
