Cisco ASR 1013 HDD
Chassis type: ASR1013
Slot      Type                State                 Insert time (ago)
0         ASR1000-SIP40       ok                    05:44:11
 0/0      SPA-1X10GE-L-V2     ok                    05:42:41
 0/1      SPA-1X10GE-L-V2     ok                    05:42:41
 0/2      SPA-1X10GE-L-V2     ok                    05:42:41
 0/3      SPA-1X10GE-L-V2     ok                    05:42:41
1         ASR1000-SIP40       ok                    05:44:11
 1/0      SPA-1X10GE-L-V2     ok                    05:42:41
 1/1      SPA-1X10GE-L-V2     ok                    05:42:41
 1/2      SPA-1X10GE-L-V2     ok                    05:42:41
 1/3      SPA-1X10GE-L-V2     ok                    05:42:41
2         ASR1000-SIP40       ok                    05:44:11
 2/0      SPA-10X1GE-V2       ok                    05:42:41
3         ASR1000-SIP40       ok                    05:44:11
 3/0      SPA-10X1GE-V2       ok                    05:42:41
R0        ASR1000-RP2         ok, active            05:44:11
R1        ASR1000-RP2         booting               05:44:11
F0        ASR1000-ESP40       ok, active            05:44:11
F1        ASR1000-ESP40       ok, standby           05:44:11
P0        ASR1013/06-PWR-AC   ok                    05:43:31
P1        ASR1013/06-PWR-AC   ok                    05:43:31
P2        ASR1013/06-PWR-AC   ok                    05:43:30
P3        ASR1013/06-PWR-AC   ok                    05:43:30
Slot      CPLD Version        Firmware Version
0         00200800            15.0(1r)S
1         00200800            15.0(1r)S
2         00200800            15.0(1r)S
3         00200800            15.0(1r)S
R0        10021901            12.2(33r)XND
R1        10021901            12.2(33r)XND
F0        1003190E            15.0(1r)S
F1        1003190E            15.0(1r)S
В общем обновлялись по инструкции: http://www.cisco.com/c/en/us/td/docs/routers/asr1000/configuration/guide/chassis/asrswcfg/issu.html#pgfId-1081554
10. issu loadversion rp standby-RP file URL-to-standby-file-system :asr1000rp* version *.pkg force
11. hw-module slot standby-RP reload
и standby-RP не загрузился
Initializing Hardware ...
Calculating the ROMMON CRC ... CRC is correct
System Bootstrap, Version 12.2(33r)XND, RELEASE SOFTWARE (fc1)
Copyright (c) 2009 by cisco Systems, Inc.
Current image running: Boot ROM0
Last reset cause: RP-Reset
ASR1000
-RP2 platform with 16777216 Kbytes of main memory
File size is 0x000027d8
Located packages.conf
Image size 10200 inode num 26, bks cnt 3 blk size 8*512
File size is 0x0253b374
Located asr1000rp2-rpbase.03.16.02.S.155-3.S2-ext.pkg
Image size 39039860 inode num 19, bks cnt 9532 blk size 8*512
Boot image size = 39039860 (0x253b374) bytes
Missing or illegal ip address for variable DEFAULT_GATEWAY
Using midplane macaddr
Missing or illegal ip address for variable IP_ADDRESS
Missing or illegal ip address for variable IP_SUBNET_MASK
Package header rev 0 structure detected
Calculating SHA-1 hash...done
validate_package
: SHA-1 hash:
        calculated
3ac5d15a:7dc2c7a7:664acd72:b9273da2:815fbb8b
        expected
Image validated
%IOSXEBOOT-4-WAIT_FOR_DEVICES: (rp/1): Partition "/dev/harddisk1" missing at 20160314125949 Continuing to initialization
%IOSXEBOOT-4-PART_INVALID: (rp/1): /dev/harddisk has an invalid partition table that must be repaired.
%IOSXEBOOT-4-PART_REPAIR: (rp/1): The system will repair /dev/harddisk now.
%IOSXEBOOT-4-PART_REPAIR: (rp/1): This may cause loss of data and configuration on /dev/harddisk.
%IOSXEBOOT-4-PART_REPAIR_FINISHED: (rp/1): Partitioning complete.
%IOSXEBOOT-4-FILESYS_INVALID: (rp/1): partition /dev/harddisk1 has an invalid filesystem that must be re-initialized.
%IOSXEBOOT-4-FILESYS_REPAIR: (rp/1): The system will repair /dev/harddisk1 now.
%IOSXEBOOT-4-FILESYS_REPAIR: (rp/1): This will cause a complete loss of data.
И вот в таком состоянии он и висит уже 12часов, он форматируется или просто умер?
Пришлось заменить диск и он загрузился, там обычный ssd диск от тошибы 80гб.
I replace hdd and it works now. There was toshiba 80gb ssd.
btw thanks for your advice about rommon version.
Iulian Vaideanu
Level 4
Level 4
Table 6 here says ROMMON version 15.2(1r)S is required for RP2 with IOS XE 3.16 (by the way, what's your current IOS XE version?):
http://www.cisco.com/c/en/us/td/docs/routers/asr1000/release/notes/asr1k_rn_rel_notes/asr1k_rn_sys_req.html#pgfId-3201398
This may not be the cause of what's happening with your /dev/harddisk (the only time I encountered a ROMMON incompatibility the symptom was that SHA-1 validation failed), but 12.2(33r)XND is way too old anyway...
current ios:
Cisco IOS Software, IOS-XE Software (X86_64_LINUX_IOSD-ADVIPSERVICESK9-M), Version 15.2(1)S, RELEASE SOFTWARE (fc1)
but sha-1 validated... idk i can upgrade rommon.
Normally you download the ROMMON image (latest is asr1000-rommon-155-3r.S1.pkg) to the router's bootflash, then "upgrade rom-monitor filename bootflash:asr1000-rommon-155-3r.S1.pkg R1" would upgrade the second RP's ROMMON.
The thing is, I'm not sure it will work in your case (while the RP is in "booting" state)...
