10-30-2019 03:43 AM
Hello All,
I am trying to configure " ip nat inside " command under the interface but router ASR 920-12CZ-A is rejecting the command.
Please support by sharing the information if this router supports the " NAT CONFIGURATION " or not.
logs shared below
*****(config)# int Gi0/0/0
*****(config)#description "DIA DOWNLINK"
*****(config)#ip address 10.1.1.1 255.255.255.0
*****(config)# ip nat inside
% Invalid input detected at '^' marker.
#sh ver
Cisco IOS XE Software, Version 03.18.00.SP.156-2.SP-ext
Cisco IOS Software, ASR920 Software (PPC_LINUX_IOSD-UNIVERSALK9_NPE-M), Version 15.6(2)SP, RELEASE SOFTWARE (fc2)
Thank you all in advance
Solved! Go to Solution.
10-30-2019 05:57 AM
10-30-2019 05:57 AM
I think only the ASR920-12SZ-IM supports NAT...
