NetFlow v9 cause high CPU on 2911
johnlloyd_13
Level 9
Level 9
hi,
we recently enabled netflow for our arbor DDOS mitigation on our internet gw.
we're getting constant alerts for high CPU after it was enabled.
the high CPU spikes only happens on a 2911 but not on our ASR1K.
2911#sh proc cpu sort
CPU utilization for five seconds: 91%/88%; one minute: 59%; five minutes: 66%
PID Runtime(uS) Invoked uSecs 5Sec 1Min 5Min TTY Process
11 4072251936 2434280 61662 1.28% 0.15% 0.07% 0 Licensing Auto U
5 2238489856 19808645 3148 0.80% 0.09% 0.06% 0 Check heaps
114 1889036448 541061350 98 0.24% 0.16% 0.15% 0 IP Input
201 382570816 129755784 135 0.16% 0.06% 0.06% 0 TPLUS
<SNIP>
2911#sh proc cpu sort | ex 0.00
CPU utilization for five seconds: 54%/53%; one minute: 61%; five minutes: 65%
278 932000 218 4275 0.39% 0.55% 0.13% 391 SSH Process
114 1890060448 541063569 98 0.31% 0.22% 0.18% 0 IP Input
273 3253365632 145028088 259 0.07% 0.06% 0.06% 0 SNMP ENGINE
271 2208534816 289845438 66 0.07% 0.04% 0.04% 0 IP SNMP
201 382878816 129756272 135 0.07% 0.06% 0.06% 0 TPLUS
23 1044000 513 2035 0.07% 0.06% 0.06% 388 SSH Process
1) is the 2911 capable of handling netflow?
interface GigabitEthernet0/1
description ### ISP WAN ###
bandwidth 100000
ip address <IP> 255.255.255.252
ip flow monitor NETFLOW sampler sampler-1-in-1000 input
2) can i tweak the sampling rate to "lower" down the CPU?
sampler SAMPLER-1-in-1000
mode random 1 out-of 1000
3) do i need to upgrade the IOS? or upgrade the HW to an ASR?
2911#sh ver
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.0(1)M4, RELEASE SOFTWARE (fc1)
your IOS (as you have indicated yourself) is rather outdated, try and upgrade to 15.7.3M5 MD.
That's not a guarantee that v9 will max out your CPU, as the 2911 is less powerful than the ASR1K. Is using the 'old' ip flow-export an option at all ?
