Cisco ASR (ISG functions) and SNMP
ASR 1002-X (IOS XE) routers for create internet access. I need to have clean the user's session on SNMP (from CLI command this: "clear ip subscriber session uid xxx").
On Cisco WEB-site I see CISCO-SUBSCRIBER-SESSION-MIB for this operations (ftp://ftp.cisco.com/pub/mibs/v2/CISCO-SUBSCRIBER-SESSION-MIB.my).
With use of this MIB I have READ-ONLY (snmpwalk) information on sessions and services from ISG, I cannot WRITE (snmpset) parameters (clear session for example).
As with the help of SNMP and this MIB I can make clear subscriber session?
Thanks.
pieterh
I'm not sure but maybe you can not clear individual session, only clear all sessions
this matches your question better
https://snmp.cloudapps.cisco.com/Support/SNMP/do/BrowseOID.do?local=en&translate=Translate&objectInput=csubJobEntry#oidContent
when you hover over "object details" you will read you most create a job type : "subscriber session query"
probably that is the read-only result what you've allready got?
and then perform another job with type "subscriber session clear"
