overlapping networks
qasim khan
The solution will be to use vrf  Lite or MPLS.
If you are operating over a WAN you will definitely have to consider implementing mpls vpnv4 for the transportation of each vpn tunnel, as you will need to export and import route targets RT along with creating a unique route distinguisher  RD for each 1.1.1X  network so asoto keep them unique across your WAN.
A bit of Route Leaking will be involved  that will allow connectivity to your remote overlapping net from the server network perspective.
P.Williams
balaji.bandi
couple of solution i can think of, but what device between these network ? do you have FW ? ( any network digram to choose right solution.
NAT :
https://www.cisco.com/c/en/us/support/docs/ip/network-address-translation-nat/200726-Configure-NAT-to-Enable-Communication-Be.html
VRV
http://www.mustbegeek.com/configure-vrf-in-cisco-ios-router/
BB
Hi Guys.
I believe I have got this working so you don't have to reply if you dont want to :)
but if curious to know how I did it let me know and I will share my config with you.
