NAT Overload with ACL
Andrew White
Level 2
Level 2
I'm setting up a small office which has 5 small subnets and a Cisco router to the Internet, their ASA firewall has not arrived so I'm setting up the router with NAT overload.  At the moment I have 1 access list which is an 'any any' type rule and allows all subnets internet access on all ports.
2.) How can I give the users subnets access to TCP/80 and 443 only (172.16.10.x/24 & 172.16.11.x/24) and the server subnet (172.16.1.x/24) full access?
1.) Once the firewall is in I will control it from there, but I'm not sure how I will need to set the router up as this will attach to the ASAs outside after.  I will have a 0.0.0.0 0.0.0.0 (router IP) with an inside to outside NAT on the ASA as per normal, but what should I configure on the Cisco Router?
Thakns
6 Replies 6
luis_cordova
Hi @Andrew White,
I recommend you configure an extended ACL to filter the ports you mention.
This ACL can be applied to an interface or subinterface on the router.
Ah yes, I can use 1 Extended ACL and put all in that and apply to the NAT router and remove the standards ACL.
Seb Rupik
Why not apply an outbound ACL on the routers outside interface:
access-list 101 permit tcp 172.16.10.0 255.255.255.0 any eq 80
access-list 101 permit tcp 172.16.10.0 255.255.255.0 any eq 443
access-list 101 permit tcp 172.16.11.0 255.255.255.0 any eq 80
access-list 101 permit tcp 172.16.11.0 255.255.255.0 any eq 443
access-list 101 deny ip 172.16.10.0 255.255.255.0 any
access-list 101 deny ip 172.16.11.0 255.255.255.0 any
access-list 101 permit ip 172.16.1.0 255.255.255.0 any
int x/x
  desc OUTSIDE
  ip access-group 101 out
2) One you ASA arrives and is connected remove the NAT and the above ACL. The router will need a default route directed to the ISP next-hop IP, and a second route directed at the ASA outside interface for your private inside subnets. Ideally you would run a dynamic routing protocol between the two so that any new subnets added to the ASA will be known to the router.
cheers,
Seb.
something like the below should work:
access-list 101 permit ip 172.16.10.0 0.0.0.255 any eq 80
access-list 101 permit ip 172.16.10.0 0.0.0.255 any eq 443
access-list 101 permit ip 172.16.11.0 0.0.0.255 any eq 80
access-list 101 permit ip 172.16.11.0 0.0.0.255 any eq 443
access-list 101 permit ip 172.16.1.0 0.0.0.255 any
ip nat inside source list 101 interface GigabitEthernet0/0 overload
on the router, basically alll you would need is a static route pointing to the inside interface of the ASA. All NAT would be configured on the ASA...
Thanks all - really appreciate it.
On the Router and ASA I will be running OSPF (area 0)
