Cisco ASR1001-X Throughput Licence
We are running a Cisco ASR1001-X with the default 2.5Gb throughput licence, with multiple interfaces.  There is a complex way to check this with monitoring I guess and some adding up,  however,  is there a simple way to display peak throughput on the device apart from the usual reactive alerts that if you get close (95%) to the throughput
gachilleas
check this:
Show Interface Summary
The TXBS field gives the total output traffic on the router. In this example, total output traffic is 3.1G (2680945000 + 372321000 = 3053266000).
Router#sh int summary
 *: interface is up
 IHQ: pkts in input hold queue     IQD: pkts dropped from input queue
 OHQ: pkts in output hold queue    OQD: pkts dropped from output queue
 RXBS: rx rate (bits/sec)          RXPS: rx rate (pkts/sec)
 TXBS: tx rate (bits/sec)          TXPS: tx rate (pkts/sec)
 TRTL: throttle count
  Interface                   IHQ       IQD       OHQ       OQD      RXBS      RXPS      TXBS      TXPS      TRTL
  GigabitEthernet0/0/0          0         0         0         0         0         0         0         0         0
  GigabitEthernet0/0/1          0         0         0         0         0         0         0         0         0
  GigabitEthernet0/0/2          0         0         0         0         0         0         0         0         0
  GigabitEthernet0/0/3          0         0         0         0         0         0         0         0         0
* Te0/1/0                       0         0         0         0 383941000    152887 2680945000    265668        0
* Te0/2/0                       0         0         0         0 2541026000    254046 372321000    147526        0
  GigabitEthernet0              0         0         0         0         0         0         0         0         0
* Loopback0                     0         0         0         0         0         0         0         0         0
 this is taken from the following:
https://www.cisco.com/c/en/us/support/docs/routers/asr-1000-series-aggregation-services-routers/200674-Throughput-issues-on-ASR1000-Series-rout.html
Thanks for the reply,  that`s a handy command actually but doesn't give me peak, only the current. It would be handy to have a counter for the TXBS but peak, so I can work out where we sit within the 2.5Gbits throughput licencing.
Lee.
