cisco asr1001x doesn't turn on TenGige interface
unfraget1
hi guys!
I have issue with connect asr1001x to juniper mx240, on asr doesn't up interface TenGig.
In logs i see follow error
Mar  6 11:21:39 UTC: %IOSXE_RP_ALARM-6-INFO: ASSERT CRITICAL xcvr container 0/0/0 Transceiver Missing - Link Down
Mar  6 11:21:39 UTC: %ALARM-3-CLEAR: CLEAR CRITICAL TenGigabitEthernet0/0/0 Physical Port Link Down entity deleted
Mar  6 11:21:39 UTC: %TRANSCEIVER-6-REMOVED: SIP0/0: Transceiver module removed from TenGigabitEthernet0/0/0
Mar  6 11:21:56 UTC: %TRANSCEIVER-6-INSERTED: SIP0/0: transceiver module inserted in TenGigabitEthernet0/0/0
Mar  6 11:21:58 UTC: %IOSXE_RP_ALARM-6-INFO: CLEAR CRITICAL xcvr container 0/0/0 Transceiver Missing - Link Down
Mar  6 11:21:58 UTC: %IOSXE_RP_ALARM-6-INFO: ASSERT CRITICAL TenGigabitEthernet0/0/0 Physical Port Link Down
Mar  6 11:21:58 UTC: %IOSXE_SPA-6-UPDOWN: Interface TenGigabitEthernet0/0/0, link down due to local fault
Mar  6 11:21:59 UTC: %IOSXE_SPA-6-UPDOWN: Interface TenGigabitEthernet0/0/0, link down due to local fault
Mar  6 11:22:03 UTC: %IOSXE_SPA-6-UPDOWN: Interface TenGigabitEthernet0/0/0, link down due to local fault
Mar  6 11:22:05 UTC: %IOSXE_SPA-6-UPDOWN: Interface TenGigabitEthernet0/0/0, link down due to remote fault
Cisco IOS XE Software, Version 16.06.02
Cisco IOS Software [Everest], ASR1000 Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 16.6.2, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
sh platform
Chassis type: ASR1001-X
Slot Type State Insert time (ago)
0 ASR1001-X ok 23:36:31
0/0 BUILT-IN-2T+6X1GE ok 23:35:16
R0 ASR1001-X ok, active 23:36:31
F0 ASR1001-X ok, active 23:36:31
P0 ASR1001-X-PWR-AC ok 23:36:07
P1 ASR1001-X-PWR-AC ok 23:36:06
P2 ASR1001-X-FANTRAY ok 23:36:08
Slot CPLD Version Firmware Version
0 14041015 16.3(2r)
R0 14041015 16.3(2r)
F0 14041015 16.3(2r)
however, SFP module was defined, and i can retrieve some parameters:
sh hw-module subslot 0/0 transceiver 0 idprom detail
IDPROM for transceiver TenGigabitEthernet0/0/0:
  Description                               = SFP+ optics (type 130)
  Transceiver Type:                         = SFP+ 10GBASE-ER (276)
  Product Identifier (PID)                  = SFP-10G-ER
  Vendor Revision                           = A
  Serial Number (SN)                        = EA110928016
  Vendor Name                               = OEM
  Vendor OUI (IEEE company ID)              = 00.90.65 (36965)
  CLEI code                                 = COUIAM3CAA
  Cisco part number                         = 10-2415-01
  Device State                              = Enabled.
  Date code (yy/mm/dd)                      = 11/10/26
  Connector type                            = LC.
  Encoding                                  = 8B10B
  Nominal bitrate                           = 10GE (10300 Mbits/s)
  Minimum bit rate as % of nominal bit rate = 103 % of 10300 Mbits/s
  Maximum bit rate as % of nominal bit rate = 99 % of 10300 Mbits/s
  The transceiver type is 276
  Link reach for 9u fiber (km)              = ER(40km) (40)
                                              8GFC-ER(40km) (40)
                                              8GFC-CWDM(40km) (40)
  Link reach for 9u fiber (m)               = ER(40km) (255)
                                              ZR(80km) (255)
                                              DWDM(80km) (255)
                                              8GFC-ER(40km) (255)
                                              8GFC-CWDM(40km) (255)
  Nominal laser wavelength                  = 1558 nm.
  DWDM wavelength fraction                  = 1558.0  nm.
  Supported options                         = Tx disable
                                              Tx fault signal
                                              Loss of signal (standard implementation)
  Supported enhanced options                = Alarms for monitored parameters
                                              Software Tx fault monitoring
                                              Software Rx LOS monitoring
  Diagnostic monitoring                     = Digital diagnostics supported
                                              Diagnostics are internally calibrated
                                              Rx power measured is "Average power"
  Transceiver temperature operating range   = not specified
  Minimum operating temperature             = 0 C
  Maximum operating temperature             = 70 C
  High temperature alarm threshold          = +85.000 C
  High temperature warning threshold        = +80.000 C
  Low temperature warning threshold         =  -5.000 C
  Low temperature alarm threshold           =  -10.000 C
  High voltage alarm threshold              = 3700.0 mVolts
  High voltage warning threshold            = 3599.9 mVolts
  Low voltage warning threshold             = 3000.0 mVolts
  Low voltage alarm threshold               = 2900.0 mVolts
  High laser bias current alarm threshold   = 85.000 mAmps
  High laser bias current warning threshold = 80.000 mAmps
  Low laser bias current warning threshold  = 12.000 mAmps
  Low laser bias current alarm threshold    = 10.000 mAmps
  High transmit power alarm threshold       =  6.0 dBm
  High transmit power warning threshold     =  5.0 dBm
  Low transmit power warning threshold      = -2.0 dBm
  Low transmit power alarm threshold        = -3.0 dBm
  High receive power alarm threshold        =  0.0 dBm
  High receive power warning threshold      = -1.0 dBm
  Low receive power warning threshold       = -16.0 dBm
  Low receive power alarm threshold         = -17.0 dBm
  External Calibration: bias current slope  = 1.000
  External Calibration: bias current offset = 0
sh int TenGigabitEthernet0/0/0
TenGigabitEthernet0/0/0 is down, line protocol is down
  Hardware is BUILT-IN-2T+6X1GE, address is a46c.2af7.d600 (bia a46c.2af7.d600)
  MTU 9216 bytes, BW 10000000 Kbit/sec, DLY 10 usec,
  Keepalive not supported
  Full Duplex, 10000Mbps, link type is force-up, media type is SFP-ER
  output flow-control is on, input flow-control is on
  Last input never, output never, output hang never
  Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 input errors, 0 CRC, 3 frame, 0 overrun, 0 ignored
     0 watchdog, 0 multicast, 0 pause input
     0 packets output, 0 bytes, 0 underruns
     0 output errors, 0 collisions, 6 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
What could be the problem?
8 Replies 8
Joseph W. Doherty
Do you have the license enabled for the 10g port?
Yes, i do.
Te0/0/1 interfase it's work, but with another module.
In Te0/0/1 has inserted SFP+ 10GBASE-LR.
In Te0/0/0 has inserted SFP+ 10GBASE-ER
p.s command "service unsupported-transceiver" enabled.
sounds like a layer 1 physical problem. What do you have on the Juniper side (which MIC) ?
Try and reverse the fiber strands, that is something Reza has recommended quite often, and it quite often solves the issue...:)
He Georg!
Between ASR and Juniper has installed transponder. transponder is showing optical parameters, on the transponder has had link.
also interface Te0/0/0 has optical parameters
I can't possibly changing fiber because it's one. :)
Helllo,
what is the brand/type of the transponder ? Can you remove the transponder and connect the Cisco directly to the MX240 ?
With reversing the fiber strands I meant reversing the way the fiber is connected to the SFP. Have a look at the picture in the link, try and change the way the blue connectors go into the SFP.
https://www.fs.com/support/cisco-compatible-10gbase-er-sfp+-optical-cabling-connection-141
transponder - this is DWDM.
i will try change the way the fiber is connected to the SFP, but this just in monday ^__^
hello
We've switched fiber from asr to jun ex4500 and link has raised.
well, we'll be downgrade IOS
Hi!
as i've thought, solution to this problem has been downgrade IOS to more legacy version.
after downgrade ios to 03.16.06.S port is work.
p.s in versions 9.16.03.05 and 9.16.06.02 has a problem discribed above. it's a pity
