- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
03-19-2018 08:17 AM - edited 03-05-2019 10:08 AM
Hello, I have ISR 886VA. I need to configure a custom port forwarding: allow 80 port to a host from particular IP network?
Do i do everything right? I would try it myself on Cisco but I could interrupt the current sessions.
#conf t (config)#ip access-list extended 102 (config-ext-nacl)#permit tcp host 10.255.0.100 eq 80 XXX.XXX.XXX.XXX 0.0.0.255 eq 80 (config-ext-nacl)#permit ip any any (config-ext-nacl)#exit (config)#interface Dialer0 (config-if)#ip access-group 102 in (config-if)#end #wr
Do I need to add:
ip nat inside source static tcp 10.255.0.100 80 interface Dialer0 80
Thank you in advance.
Solved! Go to Solution.
- Labels:
Other Routing
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-26-2018 11:39 PM
My mistake was that I tried to allow internal IP address in the ACL rule. The solution is:
(config)#ip access-list extended 102 (config-ext-nacl)#permit tcp host external.cisco.ip.address eq 80 remote.network.range 0.0.0.255 eq 80 (config-ext-nacl)#deny tcp any host external.cisco.ip.address eq www (config-ext-nacl)#permit ip any any (config-ext-nacl)#exit (config)#ip nat inside source static tcp dmz.server.ip.address 80 interface Dialer0 80 (config)#interface Dialer0 (config-if)#ip access-group 102 in (config-if)#end wr
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-26-2018 11:39 PM
