Cisco C819G-4G
matteo.benaroyo
Hello everybody,
I recently bought a Cisco C819G-4G, does anyone setup the 4G on this router? I've two different SIM card inside, the ISP are Vodafone and TIM. I'm from Italy.
Best regards.
5 Replies 5
paolo bevilacqua
There is no 4G service in Italy yet.
You will do a normal configuration as per documentation. You will need to engage a reputable network engineer unless your want to spend a lot of time and frustration learning by yourself.
Paolo,
I think you're wrong, because Rome is covered by 4G/LTE service actually.
The problem is not the configuration itself, but the provider's parameter to be included in the configuration, which are not included in the Cisco Documentation obviusly.
Best regards.
You did not specified where in Italy you are located. You will find 4G service to be spotty and inconsistent in Rome.
Anyway, there are no specific parameters to be configured. You need to have it working the normal way before worrying about 4G.
Paolo,
thanks for your response.
To avoid any LTE/4G problem i'll force the UMTS mode. I've tried to configure the GSM profile with the correct APN and the Cellular0/0 Interface with default parameter and IP Address negotiated. The Interface goes UP but without IP Address.
Later I'll post the configuration if it's helpful. Any advice?
Finally I've found a working configuration. My carrier is Vodafone, but I suppose it'll works with any carrier changing the APN.
1) Configure the Cellular Profile:
cellular 0 lte profile 1 web.omnitel.it
2) Configure the Cellular 0 Interface:
interface Cellular0
      ip address negotiated
      ip nat outside
      ip virtual-reassembly in
      encapsulation slip
      dialer in-band
      dialer string UMTS
      dialer-group 1
3) Configure the Chat Script
chat-script UMTS "" "AT!CALL" TIMEOUT 60 "OK"
4) Configure the default Route pointing to the Cellular Interface
ip route 0.0.0.0 0.0.0.0 Cellular0
5) Configure the dialer script
dialer-list 1 protocol ip list 1
6) Configure the line (use the command show line to discover which line is used by the Cellular Interface, in my case is Line 3)
line 3
      script dialer UMTS
      modem InOut
7) Configure NAT to permit Lan client to access Internet
interface Vlan1
     ip nat inside
     end
route-map internet permit 10
     match ip address 101
     end
access-list 101 permit ip 10.10.10.0 0.0.0.255 any
ip nat inside source route-map internet interface Cellular0 overload
After this configuration everything works perfectly.
