Cisco C881G-4G will not activate cellular profile
BeckyBoo123
Hi all,
Would anyone mind looking over my config for me and seeing if I have done anything blatantly wrong. This is a new C881G-4G which I have setup using the config from an identical router running exactly the same config, and using the same providers sim card.
The aim is to get the router to connect to the cellular network and then VPN to our HQ but I am struggling to get it to even connect to 4G.
router#sh cell 0 all
Hardware Information
Modem Firmware Version = SWI9X15C_05.05.58.00
Modem Firmware built = 2015/03/04 21:30:23
Hardware Version = 1.0
Device Model ID: MC7304
Package Identifier ID: 1102029_9903299_MC7304_05.05.58.00_00_Cisco_005.010_000
International Mobile Subscriber Identity (IMSI) =
International Mobile Equipment Identity (IMEI) = 352761061970175
Integrated Circuit Card ID (ICCID) =
Mobile Subscriber Integrated Services
Digital Network-Number (MSISDN) =
Current Modem Temperature = 0 deg C
PRI SKU ID = 9903299, PRI version = 05.10, Carrier = 1
Profile Information
Profile password Encryption level: 7
Profile 1 = INACTIVE* **
PDP Type = IPv4
Access Point Name (APN) = everywhere
Authentication = CHAP
Username: eesecure
Password: 095F4B0A0C1712
  * - Default profile
 ** - LTE attach profile
Configured default profile for active SIM 0 is profile 1.
Data Connection Information
Profile 1, Packet Session Status = INACTIVE
Profile 2, Packet Session Status = INACTIVE
Profile 3, Packet Session Status = INACTIVE
Profile 4, Packet Session Status = INACTIVE
Profile 5, Packet Session Status = INACTIVE
Profile 6, Packet Session Status = INACTIVE
Profile 7, Packet Session Status = INACTIVE
Profile 8, Packet Session Status = INACTIVE
Profile 9, Packet Session Status = INACTIVE
Profile 10, Packet Session Status = INACTIVE
Profile 11, Packet Session Status = INACTIVE
Profile 12, Packet Session Status = INACTIVE
Profile 13, Packet Session Status = INACTIVE
Profile 14, Packet Session Status = INACTIVE
Profile 15, Packet Session Status = INACTIVE
Profile 16, Packet Session Status = INACTIVE
Network Information
Current System Time = Sun Jan 6 0:4:18 1980
Current Service Status = No service
Current Service = Unknown
Current Roaming Status = Home
Network Selection Mode = Automatic
Network =
Mobile Country Code (MCC) = 234
Mobile Network Code (MNC) = 15
Packet switch domain(PS) state = Not attached
Location Area Code (LAC) = 0
Cell ID = 0
Radio Information
Radio power mode = online
Channel Number = 0
Current Band = Unknown
Current RSSI(RSCP) = -83 dBm
Current ECIO = -8 dBm
Primary Scrambling Code = 352
Radio Access Technology(RAT) Preference = AUTO
Radio Access Technology(RAT) Selected = UMTS
Modem Security Information
Active SIM = 0
SIM switchover attempts = 0
Card Holder Verification (CHV1) = Disabled
SIM Status = Not inserted
SIM User Operation Required = None
Number of CHV1 Retries remaining = 0
GPS Information
GPS Info
GPS Feature: enabled
GPS Port Selected: Dedicated GPS port
GPS State: GPS location error
GPS auto tracking status: unknown
GPS auto tracking config: disabled
GPS Mode Configured: disabled
Last Location Fix Error: Offline [0x0]
SMS Information
Incoming Message Information
SMS stored in modem = 0
SMS archived since booting up = 0
Total SMS deleted since booting up = 0
Storage records allocated = 25
Storage records used = 0
Number of callbacks triggered by SMS = 0
Number of successful archive since booting up = 0
Number of failed archive since booting up = 0
Outgoing Message Information
Total SMS sent successfully = 0
Total SMS send failure = 0
Number of outgoing SMS pending = 0
Last Outgoing SMS Status = SUCCESS
Copy-to-SIM Status =     0x0
Send-to-Network Status = 0x0
Report-Outgoing-Message-Number:
  Reference Number =     0
  Result Code =          0x0
  Diag Code =            0x0 0x0 0x0 0x0 0x0
SMS Archive URL =
Error Information
This command is not supported on this platform.
Modem Crashdump Information
Modem crashdump logging: off
As you can see, the profile is inactive, but I do not know why. Is there anything I can do to force it to be active?
router#sh running-config
Building configuration...
Current configuration : 4640 bytes
version 15.5
service password-encryption
hostname router
boot-start-marker
boot-end-marker
no logging console
aaa new-model
aaa authentication login default local
aaa authentication enable default enable
aaa authorization exec default local
aaa session-id common
ethernet lmi ce
clock timezone gmt 0 0
clock summer-time gmt recurring
no ip domain lookup
ip domain name mycompany.local
ip name-server 10.11.2.5
ip name-server 8.8.8.8
ip cef
no ipv6 cef
chat-script lte "" "AT!CALL" TIMEOUT 20 "OK"
license udi pid C881G-4G-GA-K9 sn FCZ2104E1GY
object-group network HGL-IPs
 host xx.xx.140.115
 host xx.xx.136.202
 host xx.xx.55.162
 host xx.xx.51.246
username administrator privilege 15 secret 5 $1$XhIZ$31LWqasCpbR64BrWYXi/A/
controller Cellular 0
 lte sim data-profile 1 attach-profile 1 slot 0
 lte modem link-recovery rssi onset-threshold -110
 lte modem link-recovery monitor-timer 20
 lte modem link-recovery wait-timer 10
 lte modem link-recovery debounce-count 6
no cdp run
crypto logging session
crypto logging ezvpn
crypto isakmp policy 1
 encr aes
 authentication pre-share
 group 2
crypto isakmp key password address xx.xx.136.202
crypto isakmp keepalive 10 periodic
crypto ipsec security-association lifetime kilobytes 5000000
crypto ipsec security-association lifetime seconds 8640
crypto ipsec transform-set TS esp-aes esp-sha-hmac
 mode tunnel
crypto ipsec fragmentation after-encryption
crypto map VPN-TO-HQ 10 ipsec-isakmp
 set peer 81.128.136.202
 set transform-set TS
 match address VPN-TRAFFIC
interface Cellular0
 description Primary cellular WAN link
 ip address negotiated
 ip access-group LOCKDOWN-IN in
 ip access-group LOCKDOWN-OUT out
 encapsulation slip
 dialer in-band
 dialer string lte
 dialer-group 1
 async mode interactive
 routing dynamic
interface Cellular1
 no ip address
 encapsulation slip
interface FastEthernet0
 switchport access vlan 109
 no ip address
interface FastEthernet1
 no ip address
interface FastEthernet2
 no ip address
interface FastEthernet3
 no ip address
interface FastEthernet4
 no ip address
 shutdown
 duplex auto
 speed auto
interface Vlan1
 no ip address
 shutdown
interface Vlan109
 ip address 10.11.109.254 255.255.255.0
 ip helper-address 10.11.202.1
 no ip proxy-arp
 ip nbar protocol-discovery
 ip tcp adjust-mss 1452
 load-interval 30
interface Dialer1
 encapsulation slip
 dialer pool 1
 dialer idle-timeout 0
 dialer string lte
 dialer persistent
 dialer-group 1
no ip forward-protocol nd
no ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 Cellular0
ip ssh version 2
ip ssh server algorithm encryption aes128-ctr aes192-ctr aes256-ctr
ip ssh client algorithm encryption aes128-ctr aes192-ctr aes256-ctr
ip access-list extended LOCKDOWN-IN
 permit udp any any eq bootps
 permit udp any any eq bootpc
 permit gre object-group HGL-IPs any
 permit esp object-group HGL-IPs any
 permit ahp object-group HGL-IPs any
 permit ip object-group HGL-IPs any
ip access-list extended LOCKDOWN-OUT
 permit udp any object-group HGL-IPs
 permit ahp any object-group HGL-IPs
 permit esp any object-group HGL-IPs
 permit gre any object-group HGL-IPs
 permit ip any object-group HGL-IPs
ip access-list extended VPN-TRAFFIC
 permit ip 10.11.109.0 0.0.0.255 any
dialer-list 1 protocol ip permit
snmp-server community hgp-ro RO
snmp-server location Roaming Router
snmp-server contact Group IT
snmp-server chassis-id router
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
 privilege level 15
 no modem enable
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
 stopbits 1
line 3
 script dialer lte
 no exec
line 8
 no exec
line vty 0 4
 exec-timeout 1440 0
 privilege level 15
 transport input ssh
line vty 5 15
 exec-timeout 1440 0
 privilege level 15
 transport input ssh
scheduler allocate 20000 1000
ntp server ntp.mycompany.local source Cellular0
end
Any advice would be appreciated, thank you for your time :)
11 Replies 11
omz
Sorry not familiar with cellular.
But you may want to sanitise the config before posting on public forum :) you have masked some public IPs with xx but missed ..
crypto isakmp key xxxx address x.x.x.x
Thank you for pointing that out! I had gone through it but missed that one, could you also omit that information from your reply please? :)
Thanks for that link, I had seen that but the poster does not tell us how to force a GSM network.
Would you know how to do that?
Thanks.
omz
Is this relevant?
https://www.cisco.com/c/en/us/td/docs/routers/access/interfaces/software/feature/guide/ehwic-4g-ltesw-book.html
Searching the Network
You can use the cellular 0 lte plmn search command to search for available PLMNs. The following example shows how to search for networks:
router#cellular 0 lte plmn search
Searching for available PLMNs.This may take up to 3 minutes.
Please wait...........................
PLMN search done. Please use "show cellular 0 network" to see available PLMNS
After the search, use the show cellular 0 network command to see the available networks:
router#show cellular 0 network
Current System Time = Fri Sep 18 18:49:24 2015
Current Service Status = Normal
Current Service = Packet switched
Current Roaming Status = Roaming
Network Selection Mode = Manual
Network = O2 - UK
Mobile Network Code (MNC) = 10
Packet switch domain(PS) state = Attached
Location Area Code (LAC) = 4931
Cell ID = 34319
Available PLMNs:
Idx MCC MNC RAT     Desc
1   234 10  umts    O2 - UK
2   234 10  gsm     O2 - UK
3   234 20  umts    3 UK
4   234 30  umts    EE
5   234 15  gsm     voda UK
6   234 33  gsm     EE
7   234 20  lte     3 UK
8   234 30  gsm     EE
9   234 15  umts    voda UK
10  234 30  lte     EE
11  234 10  lte     O2 - UK
12  234 15  lte     voda UK
Selecting the Network
There are three ways to select an available network: Auto mode, Force Mode, and Manual mode. In Auto mode, the router will connect automatically to a network preferred by the SIM card. In Force mode, the router is forced to select an available or known network without performing a network search. If a network is not available or the router is unable to attach to a network, then the router will remain in a ‘Not attached’ state. You can use the cellular x lte plan select auto command to attach the router to a network preferred by the SIM. In Manual mode, you can select an available network from your search result.
The following example shows how to select a network manually:
router#cellular 0 lte plmn select manual ?
	0-999 Mobile Country Code (MCC)
router#cellular 0 lte plmn select manual 234 ?
	0-999 Mobile Network Code (MNC)
router#cellular 0 lte plmn select manual 234 10 ?
  gsm   GSM
  lte   LTE
  umts  UMTS
router#cellular 0 lte plmn select manual 234 10 gsm ?
The following example shows how to force a network selection:
router#cellular 0 lte plmn select force ?
router#cellular 0 lte plmn select force 310 ?
router#cellular 0 lte plmn select force 310 410 ?
	2-3 MNC Digits Ex 23 means 2 Digits, 023 Means 3 Digits
router#cellular 0 lte plmn select force 310 410 2 ?
  gsm   GSM
  lte   LTE
  umts  UMTS
router#cellular 0 lte plmn select force 310 410 2 l
router#cellular 0 lte plmn select force 310 410 2 lte ?
Verifying PLMN Selection
Use show cellular 0 network command to verify the PLMN selection:
Current System Time = Fri Sep 18 18:53:25 2015
Network = O2 - UK
Cell ID = 34319
Available PLMNs:
3   234 20  umts    3 UK
4   234 30  umts    EE
6   234 33  gsm     EE
7   234 20  lte     3 UK
8   234 30  gsm     EE
10  234 30  lte     EE
router#show cellular 0 radio
Radio power mode = ON
Channel Number = 122
Current Band = GSM 900 Extended
Current RSSI = -48 dBm
Current ECIO = -127 dBm
Radio Access Technology(RAT) Preference = GSM
Radio Access Technology(RAT) Selected = EDGE
Hi omc79,
This could be a useful guide if I could get it to work. I've tried over and over again and no matter what I change the settings to, using forced, auto or manual it just refuses to update anything.
For some reason its stuck on Vodafone network according to the list. Any idea how to erase the config already there?
Current System Time = Sun Jan 6 0:39:39 1980
Network =
Cell ID = 0
Available PLMNs at : 15:11:00 gmt Wed Jun 5 2019
1 234 10 gsm O2 - UK
2 234 30 gsm EE
3 234 20 lte 3 UK
4 234 10 umts O2 - UK
5 234 30 lte EE
6 234 15 umts voda UK
7 234 15 gsm voda UK
8 234 10 lte O2 - UK
9 234 15 lte voda UK
10 234 32 lte EE
do you need this router to access the Internet directly, or does the Internet access go through the other end of the VPN ?
I have changed your configuration (changes/additions marked in bold), see if that makes a difference. Typically, the VPN access list specifies traffic from your local LAN to the remote LAN on the other end. Since I don't know what your remote LAN is, I have marked it as x.x.x.x y.y.y.y):
version 15.5
hostname router
boot-start-marker
boot-end-marker
no logging console
aaa new-model
ethernet lmi ce
no ip domain lookup
ip cef
no ipv6 cef
host xx.xx.140.115
host xx.xx.136.202
host xx.xx.55.162
host xx.xx.51.246
no cdp run
encr aes
group 2
crypto isakmp key lollerskates address 81.128.136.202
mode tunnel
interface Cellular0
ip nat outside
--> no ip access-group LOCKDOWN-IN in
--> no ip access-group LOCKDOWN-OUT out
encapsulation slip
dialer in-band
dialer string lte
dialer-group 1
routing dynamic
interface Cellular1
no ip address
encapsulation slip
no ip address
no ip address
no ip address
no ip address
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
interface Vlan109
ip nat inside
no ip proxy-arp
load-interval 30
interface Dialer1
encapsulation slip
dialer pool 1
dialer string lte
dialer persistent
dialer-group 1
no ip http server
ip nat inside source list 101 interface Cellular0 overload
ip ssh version 2
access-list 101 deny ip 10.11.109.0 x.x.x.x y.y.y.y
access-list 101 permit ip 10.11.109.0 0.0.0.255 any
permit ip 10.11.109.0 0.0.0.255 x.x.x.x y.y.y.
control-plane
line con 0
privilege level 15
no modem enable
line aux 0
line 2
no exec
transport input all
stopbits 1
line 3
script dialer lte
no exec
line 8
no exec
line vty 0 4
exec-timeout 1440 0
privilege level 15
transport input ssh
line vty 5 15
exec-timeout 1440 0
privilege level 15
transport input ssh
end
Thanks Georg,
I've made the adjustments as suggested except for 'access-list 101 deny ip 10.11.109.0 x.x.x.x y.y.y.y'. I'm a bit confused what IP address I should be putting in where the x's and y's are. I tried our network 10.11.0.0 0.0.0.255 but it said the command was incomplete.
Could you advise please?
x.x.x.x y.y.y.y should be the subnet of the LAN on the other side of the VPN. You router is connected to something at the other end (the device with IP address 81.x.x.202), that device has a LAN configured. Make sure the access list on that other device is exactly the same as on the router of which you have posted the config...
have you tried to delete and recreate the profile ?
Router#cellular 0 lte profile delete 1
Router#cellular 0 lte profile create 1
I've left this for some time and come back to it in the hopes that it would start working after resting my eyes and brain but I still am in the same position.
I try to delete the profile and it won't delete, just keeps appearing.
Current System Time = Wed Jul 10 10:20:52 2019
Network =
Cell ID = 0
Available PLMNs at : 11:17:29 gmt Wed Jul 10 2019
1 234 15 umts voda UK
2 234 20 lte 3 UK
3 234 30 gsm EE
4 234 15 lte voda UK
5 234 10 lte O2 - UK
6 234 32 lte EE
7 234 10 umts O2 - UK
8 234 15 gsm voda UK
9 234 30 lte EE
10 234 10 gsm O2 - UK
I still cannot get it to display the network name or manually set it. It just ignores whatever I tell it do :(
