05-26-2022 07:42 AM
what is CISCO C921-P4 performance ( throughput ) for MPLS or Internet ?
I found 900 series data sheet (up to 150 Mbps of VPN throughput for high performance.) is it mean it can provide upto 75Mb/75Mb ?
Solved! Go to Solution.
05-26-2022 02:47 PM
They mention VPN because it is the worst case scanerio. Whithout encryption it may have better performance.
The performance does not take in account the link type, so Internet or MPLS should not do any different as long as the link supports carry the required data traffic.
About the 75Mb/75Mb will depend on how you will configured it.
05-26-2022 02:47 PM
05-29-2022 01:55 AM
Thank you
