NAT: Translating inbound destination IP
Rack&Stack
I'm struggling to figure out how I can perform NAT on ingress packets on the Gi0/1 interface of "isp-router". I want to translate the destination address to 23.1.2.100. Keep in mind this is a lab environment.
isp-router Gi0/1: ip nat outside is applied
isp-router Gi0/0: ip nat inside is applied
How can I get packets coming from the internet into my "isp-router", to translate to the address of the PA-1?
IP NAT SOURCE STATIC is Bidirectional
Inside-Global -> Inside-Local if the traffic from Onside to Inside "here the destination is NAT"
Original Source: 192.168.1.171
Original Destination: 192.168.1.61:443<-
Translated Source: 192.168.1.171
Translated Destination: 23.1.2.100:443<-
12 Replies 12
ip nat static outside <- this use to translate NAT the destination of packet
This is not what I'm looking for. I want to translate the destination packet of an INBOUND packet. Wouldn't I use ip nat inside for that since I'm translating the inside global to inside local?
simply answer is YES
meaning
Inside-Local -> Inside-GLobal  if the traffic from Inside to Outside "here the source is NAT"
I see what you mean about bidirectional. But it's asking me to put in a port for this command?
I made it work! The command that worked for me is this:
ip nat inside source static tcp 23.1.2.100 443 192.168.1.61 443
Thank you!
You are so so welcome
 Do you know which IP address will come from outside?
As far as I know, IOS does not support "ip nat outside overload",
If you know,
ip nat outside source static "outside traffic"
Yes, the source is 192.168.1.171. Translation needs to take place on ISP-Router. G0/1 is the ip nat outside interface. G0/0 is the ip nat inside interface.
Hello
There various nat types based on specific requirements, it sounds like you wish to translate to a specific destination address to a local address within your network however can you elaborate on the type of traffic you wish to translate, ip or certain udp/tcp ports?
Example (ios nat not Palto alto)
Ip nat outside static 23.1.2.100 192.168.1.2
or
ip nat outside static tcp 23.1.2.100 80 192.168.1.2 80
Kind Regards
Paul
Hi Paul,
I would like to translate traffic destined to port 443. That's the only port I need. But yes, you correctly understand what my goal is. Unfortunately that command does not work. I'm using IOSv if that helps.
Hello
Ip nat outside source static 23.1.2.100 192.168.1.2
or
ip nat outside source static tcp 23.1.2.100 80 192.168.1.2 80
Kind Regards
Paul
