Cisco can putty from one computer and not from another
chueymtz
I have a cisco 9300 switch that for some reason I can putty into from one ip scheme and not from another, this was working up until yesterday not sure what changed but when I connect from the computer that isn't working i get a refused error when I try to login.
I see that now, would I be able to copy the same login to the
vty 5 15
line? ex
access-class50 in
privilege level 15
login local
transport input all
line vty 5 15
login local
12 Replies 12
Hui @chueymtz
 Can you share the switch config ?
 Just a comment, when a problem start like this apparently with no reason, it would be a good idea reload the device.
Olga_WTP_9300#show ru
Building configuration...
Current configuration : 16961 bytes
! Last configuration change at 06:44:07 UTC Fri Jul 28 2023 by century
! NVRAM config last updated at 06:44:08 UTC Fri Jul 28 2023 by century
version 16.12
no service pad
service call-home
platform punt-keepalive disable-kernel-core
hostname O_9300
vrf definition Mgmt-vrf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
enable secret
no aaa new-model
clock timezone UTC -5 0
switch 1 provision c9300-48t
call-home
! If contact email address in call-home is configured as sch-smart-licensing@cisco.com
! the email address configured in Cisco Smart License Portal will be used as contact email address to send SCH notifications.
contact-email-addr sch-smart-licensing@cisco.com
profile "CiscoTAC-1"
active
destination transport-method http
no destination transport-method email
ip routing
ip dhcp excluded-address 10.76.x.1 10.76.x.20
ip dhcp excluded-address 172.16.x.1 172.16.x.50
ip dhcp excluded-address 172.16.x.51 172.16.x.100
ip dhcp excluded-address 172.16.x.101 172.16.x.150
ip dhcp excluded-address 172.16.x.151 172.16.x.169
ip dhcp excluded-address 172.16.6.201 172.16.x.255
ip dhcp excluded-address 10.78.x.x 10.78.x.x
ip dhcp pool Controls
network 172.16.x.0 255.255.254.0
dns-server 172.16.x.x 172.16.x.x
default-router 172.16.x.x
lease 0 4
ip dhcp pool Admin
network 10.76.x.0 255.255.255.0
default-router 10.76.x.1
dns-server 10.110.x.x 10.110.x.x
lease 0 4
ip dhcp pool Voip
network 10.78.x.0 255.255.254.0
bootfile undionly.kpxe
default-router 10.78.x.1
option 150 ip 172.21.x.x 172.21.x.x
lease 0 4
ip dhcp pool Wifi
network 192.168.x.0 255.255.255.0
default-router 192.168.x.1
dns-server 8.8.8.8 8.8.4.4
lease 0 4
login on-success log
no device-tracking logging theft
crypto pki trustpoint TP-self-signed-
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-
revocation-check none
rsakeypair TP-self-signed-
crypto pki trustpoint SLA-TrustPoint
enrollment pkcs12
revocation-check crl
license boot level network-advantage
license smart reservation
diagnostic bootup level minimal
spanning-tree mode rapid-pvst
memory free low-watermark processor 134344
username
redundancy
mode sso
transceiver type all
monitoring
class-map match-any system-cpp-police-ewlc-control
description EWLC Control
class-map match-any system-cpp-police-topology-control
description Topology control
class-map match-any system-cpp-police-sw-forward
description Sw forwarding, L2 LVX data packets, LOGGING, Transit Traffic
class-map match-any system-cpp-default
description EWLC Data, Inter FED Traffic
class-map match-any system-cpp-police-sys-data
description Openflow, Exception, EGR Exception, NFL Sampled Data, RPF Failed
class-map match-any system-cpp-police-punt-webauth
description Punt Webauth
class-map match-any system-cpp-police-l2lvx-control
description L2 LVX control packets
class-map match-any system-cpp-police-forus
description Forus Address resolution and Forus traffic
class-map match-any system-cpp-police-multicast-end-station
description MCAST END STATION
class-map match-any system-cpp-police-high-rate-app
description High Rate Applications
description MCAST Data
class-map match-any system-cpp-police-l2-control
description L2 control
class-map match-any system-cpp-police-dot1x-auth
description DOT1X Auth
class-map match-any system-cpp-police-data
description ICMP redirect, ICMP_GEN and BROADCAST
class-map match-any system-cpp-police-stackwise-virt-control
description Stackwise Virtual OOB
class-map match-any non-client-nrt-class
class-map match-any system-cpp-police-routing-control
description Routing control and Low Latency
class-map match-any system-cpp-police-protocol-snooping
description Protocol snooping
class-map match-any system-cpp-police-dhcp-snooping
description DHCP snooping
class-map match-any system-cpp-police-ios-routing
description L2 control, Topology control, Routing control, Low Latency
class-map match-any system-cpp-police-system-critical
description System Critical and Gold Pkt
class-map match-any system-cpp-police-ios-feature
description ICMPGEN,BROADCAST,ICMP,L2LVXCntrl,ProtoSnoop,PuntWebauth,MCASTData,Transit,DOT1XAuth,Swfwd,LOGGING,L2LVXData,ForusTraffic,ForusARP,McastEndStn,Openflow,Exception,EGRExcption,NflSampled,RpfFailed
policy-map system-cpp-policy
interface Loopback0
description Management
no ip address
interface GigabitEthernet0/0
vrf forwarding Mgmt-vrf
no ip address
shutdown
negotiation auto
interface GigabitEthernet1/0/1
description To_Wan_
no switchport
ip address 10.76.x.6 255.255.255.0
speed 100
duplex full
interface GigabitEthernet1/0/2
switchport access vlan 100
switchport mode access
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
description Voip Phone
switchport access vlan 500
switchport voice vlan 500
spanning-tree portfast
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
switchport access vlan 200
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface GigabitEthernet1/0/29
interface GigabitEthernet1/0/30
interface GigabitEthernet1/0/31
interface GigabitEthernet1/0/32
interface GigabitEthernet1/0/33
interface GigabitEthernet1/0/34
interface GigabitEthernet1/0/35
interface GigabitEthernet1/0/36
interface GigabitEthernet1/0/37
interface GigabitEthernet1/0/38
interface GigabitEthernet1/0/39
interface GigabitEthernet1/0/40
interface GigabitEthernet1/0/41
interface GigabitEthernet1/0/42
interface GigabitEthernet1/0/43
interface GigabitEthernet1/0/44
interface GigabitEthernet1/0/45
interface GigabitEthernet1/0/46
interface GigabitEthernet1/0/47
switchport access vlan 300
interface GigabitEthernet1/0/48
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface TenGigabitEthernet1/1/1
interface TenGigabitEthernet1/1/2
interface TenGigabitEthernet1/1/3
interface TenGigabitEthernet1/1/4
interface TenGigabitEthernet1/1/5
interface TenGigabitEthernet1/1/6
interface TenGigabitEthernet1/1/7
interface TenGigabitEthernet1/1/8
interface FortyGigabitEthernet1/1/1
interface FortyGigabitEthernet1/1/2
interface TwentyFiveGigE1/1/1
interface TwentyFiveGigE1/1/2
interface AppGigabitEthernet1/0/1
interface Vlan1
description management
no ip address
interface Vlan100
description Admin
ip address 10.76.x.x 255.255.255.0
ip access-group 101 in
interface Vlan200
description Controls
ip address 172.16.x.x 255.255.254.0
ip access-group 102 in
interface Vlan300
description Wifi
ip address 192.168.x.x 255.255.255.0
interface Vlan400
description Security
no ip address
interface Vlan500
description Voip
ip address 10.78.x.x 255.255.255.0
router eigrp 99
network 10.76.0.0 0.0.0.255
network 10.76.2.0 0.0.0.255
network 10.76.6.0 0.0.0.255
network 10.76.200.0 0.0.0.255
network 10.78.0.0 0.0.0.255
network 10.78.6.0 0.0.0.255
network 172.16.0.0
network 192.168.6.0
redistribute static metric 1000000 1 100 1 1
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip access-list standard 50
10 permit 192.168.0.0 0.0.255.255
20 permit 10.76.0.0 0.0.0.255
30 permit 10.78.0.0 0.0.0.255
ip access-list extended 101
10 deny ip any 172.16.0.0 0.0.255.255
20 permit ip any any
ip access-list extended 102
10 permit ip any 172.16.0.0 0.0.255.255
20 permit ip any 10.243.x.x 0.0.1.255
30 permit ip any 10.233.x.x 0.0.1.255
snmp-server enable traps config
snmp-server host 172.16x.x version 2c public udp-port 161
line con 0
login local
stopbits 1
line vty 0 4
access-class 50 in
privilege level 15
login local
transport input all
line vty 5 15
login
ntp server 172.16.x.x prefer
Hi @chueymtz
 thanks for the config.
You have ACL applied to the line vty
access-class 50 in
Which is the IP address you are connecting from? If the IP or network is not on the
Access list
below, you will be refused.
I am connecting from a
10.76.x.x
address which should be allowed per that
access list
but it's not going thru
Just make sure you IP address is
10.76.0.X
as per the mask used on the ACL it will be allowed to swap only the last octet.
the ip i am using is
10.76.6.x
do i need to add that to the acl? On my network we change the third octet by site.
line vty 0 4
access-class 50 in
privilege level 15
login local
transport input all
line vty 5 15
login
You have two
vty
group, one config using username/password in global and other using username/password under
vty
(there is no username/password)
So do
Show line
Check if there is user still show as connect,
What İ think happened is that
vty from 0 4
is still shown as used and sw start use
 vty 5 15
which don't have password and that why the putty is rejected
vty 5 15
line? ex
access-class50 in
privilege level 15
login local
transport input all
line vty 5 15
login local
Sure you can'
Also @Flavio Miranda consider about acl must double check
Add to check if acl drop traffic
Deny ip any any log to
access list 50
And check again.
that worked, thanks everyone.
You are so so welcome
Have a nice summer
MHM
If you use
default route
check if
no ip routing
If you use
default gateway
check
ip routing
