Cisco Catalyst 8500-12X
CSCO11864939
We would like create bundle interface like port-channel for the increase BW as 20 Gbps with two Ten Gig interfaces on the Cisco Catalyst 8500-12X router. Is it possible to do this? If possible, how can we do it?
Thanks a lot.
being a router you can use ECMP with two parallel L3 links instead of a port-channel.
By the way, the device is presented as an evolution of ASR 1000 it is a router and it is named Catalyst ...
https://community.cisco.com/t5/networking-documents/catalyst-8500-series-deep-dive-community-live-faq/ta-p/4185323
Hope to help
Giuseppe
balaji.bandi
As per the documenation have not seen any comnfiguration guide :
as per feature navigator it does support DNA-Advantage.
https://cfnng.cisco.com/browse/routing/features
BB
CSCO11864939
I already checked feature navigator so it is telling to Catalyst 8500 platform is supported to Lacp with IOS XE version17.3.2 but neither cisco.com/support nor other cisco sources doesn't included any configuration guide for the IOS XE 17.3.2.
Hope to help
Giuseppe
Dear Giuseppe,
Thanks a lot,
