Cisco command to check and verify if load balancing is working or not
josemon
Jaderson Pessoa
I cant understand your doubt;
load balance of wans: show standby
to supervisors: show redundancy states
I dont know what you need... but, maybe commands above would help you.
Jaderson Pessoa
*** Rate All Helpful Responses ***
Giuseppe Larosa
Hello Josemon,
you should provide more details in order to get better help.
If load balancing is performed by a single network device you can check the IP routing table with
show ip route <prefix>
if two or more routes are installed load balancing is occurring.
If you are interested in verifying which link is used for a specific flow there is another command
show ip cef exact-route
To display the exact route for a source-destination IP address pair for a Cisco Express Forwarding (CEF) instance, use the show ip cef exact-route command in user EXEC or privileged EXEC mode.
see
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipswitch/command/isw-cr-book/isw-s1.html#wp6959507050
This command may be not available on all platforms.
Hope to help
Giuseppe
Joseph W. Doherty
For what kind of load balancing?
