Cisco Config-Register 0x2922 Purpose
Ramu Ch
Dear Team,
Kindly confirm that if my Router with Confgiuration register OX2922 , will it gives Problem in Future or While Booting or Configuration files savings etc.
Kindly clatify me the Defference between Default-Configuration Register value 0x2102 and user-defined value Ox2922,
Ramu
Mahesh Gohil
Level 7
Level 7
Hello Ramu,
Can you try to figure out the use of 2922 on your own with below details:
The configuration register can be used to change Cisco router behavior in several ways, such as:
How the router boots (into ROM Monitor (ROMmon) or NetBoot).
Options while booting (ignore configuration, disable boot messages).
Console speed (baud rate for a terminal emulation session).
Config Register #
Bit Number
15 14 13 12
11 10 9 8
7 6 5 4
3 2 1 0
Binary
0    0    1    0
1    0   0 1
0 0 1 0
0 0 1 0
Bit Number
Hexadecimal
Meaning
00 to 03
0x0000 to 0x000F
Boot field
06
0x0040
Causes system software to ignore NVRAM contents
07
0x0080
OEM bit enabled
08
0x0100
Break disabled
09
0x0200
Use secondary bootstrap
0x0400
IP broadcast with all zeros
11 to 12
0x0800 to 0x1000
Console line speed (default is 9600 baud)
13
0x2000
Boot default Flash software if network boot fails
14
0x4000
IP broadcasts do not have network numbers
15
0x8000
Enable diagnostic messages and ignore NVRAM contents
5,11,12
0x0020, 0x0800, 0x1000
  • Console line speed
Mahesh
