06-14-2005 05:55 AM - edited 03-03-2019 09:48 AM
We are looking to replace 3 separate Internet T1s from various providers with a single provider's T3. T3 would employ all remote site IPSec VPNs, Cisco client VPNs, as well as general internet access. What Cisco router, modules, specs would be recommended? Thanks !!!
06-16-2005 07:44 AM
depending on what platform you have, most routers have a T3 module. You can usually find it on the Cisco Product Pages under ' Relevant Modules and Interfaces'. Below is a link to the T3/E3 module NM for the 2600/3600/3700 series:
Cisco 2600/3600/3700 Series T3/E3 Network Module
http://www.cisco.com/en/US/products/hw/modules/ps2797/products_data_sheet09186a008010fba2.html
HTH,
GP
06-16-2005 09:04 AM
Thanks GP !
I have looked at the module as well. I was more looking for suggestions/recommendations on a specific router. I am trying to determine which router could best handle my requirements (without price overkill) - I'm currently investigating the 7301 and 3825.
Thanks again !!!
