10-14-2014 09:00 AM - edited 03-04-2019 11:58 PM
So the problem im having with these Edge 340 devices is that im not able to update the firmware version. I will try and load the new firmware image to the OPT folder remotely but before it finished it states the drive is full. When this happens i cannot login to the web interface. It will come up to the login page but when i enter the credentials and click login it does nothing. I can remedy this by deleting the file i attempted to upload freeing up space on the root but the problem still persists that im not able to upgrade.
The main reason for needing to upgrade to Version 1.1 is we have a media presentation that auto loads when the box is turned on. For some reason when the box reboots itself once a day it will come up to the login screen and you will need to plug in a keyboard and to manually login to get to the media presentation. This does not happen on the new firmware. The unfortunate part is once it gets to this point i am unable to do anything as the Root becomes too full to hold the update.
Any assistance would be greatly appreciated.
Solved! Go to Solution.
11-18-2014 12:07 PM
The root partition is full....Need to delete the root mail.
[root@CE340 /]# cd var
[root@CE340 var]# cd mail
[root@CE340 mail]# ls
root rpc user
[root@CE340 mail]# ls -lah
total 1.1G
drwxrwxr-x. 2 root mail 4.0K Nov 14 17:04 .
drwxr-xr-x. 13 root root 4.0K Mar 28 2014 ..
-rw------- 1 root root 1.1G Nov 14 17:04 root<-----------------------
-rw-rw----. 1 rpc mail 0 Mar 28 2014 rpc
-rw-rw----. 1 user mail 0 Mar 28 2014 user
[root@CE340 mail]# pwd
/var/mail
[root@CE340 mail]# > /var/spool/mail/root
total 8.0K
-rw------- 1 root root 0 Nov 18 12:51 root<----------------------
[root@CE340 mail]# cd /
[root@CE340 /]# df -h
Filesystem Size Used Avail Use% Mounted on
devtmpfs 994M 0 994M 0% /dev
tmpfs 1001M 4.0K 1001M 1% /dev/shm
tmpfs 1001M 692K 1000M 1% /run
/dev/mapper/SysVG-lvroot 4.0G 2.8G 1.1G 73% /<-----------------------
tmpfs 1001M 0 1001M 0% /sys/fs/cgroup
tmpfs 1001M 0 1001M 0% /media
/dev/sda2 248M 31M 205M 14% /boot
/dev/mapper/SysVG-lvhome 25G 328M 24G 2% /home
11-18-2014 12:07 PM
root rpc user
total 1.1G
/var/mail
total 8.0K
