Load balancing using GLBP
M Talha
Dear All,
I need to built a scenario where i am using two ISP's for redundancy for my internal network and at the same time wants to load balance in such a way that my first packet going outside the network (using NAT) goes from first ISP's public ip address and second packet going outside the network (using NAT) goes from second ISP's public ip address.
Need your help
Thank You
Hello
I tried to lab this up - I managed to use a first hop protocol (hrsp) to a redundant HRSP & NAT configuration - however I have tried GLBP and at present not been successful in getting it to work-
Here is what I got with HRSP:
      --- R2
r1 -----        internet host 100.100.100.100
     ---- R3
R2
interface FastEthernet0/0
Description Link to LAN
 ip address 10.1.123.252 255.255.255.0
 ip nat inside
 standby 123 ip 10.1.123.254
 standby 123 priority 115
 standby 123 preempt
 standby 123 name HRSP1
 standby 123 track FastEthernet0/1 50
interface FastEthernet0/1
Description Link to ISP1
 ip address 1.1.1.2 255.255.255.0
 ip nat outside
 standby 234 ip 1.1.1.254
 standby 234 priority 115
 standby 234 preempt
 standby 234 name HRSP2
 standby 234 track FastEthernet0/0 50
ip route 100.100.100.100 255.255.255.255 FastEthernet0/1 1.1.1.4
ip nat inside source static 10.1.123.251 1.1.1.1 redundancy HRSP1
R3
 ip address 10.1.123.253 255.255.255.0
 ip nat inside
 standby 123 preempt
 standby 123 track FastEthernet0/0
Description Link to ISP2
 ip address 1.1.1.3 255.255.255.0
 ip nat outside
 standby 234 preempt
 standby 234 track FastEthernet0/1 50
R2#sh ip nat translations
Pro Inside global      Inside local       Outside local      Outside global
icmp 1.1.1.1:7         10.1.123.251:7     100.100.100.100:7  100.100.100.100:7
icmp 1.1.1.1:12        10.1.123.251:12    100.100.100.100:12 100.100.100.100:12
--- 1.1.1.1            10.1.123.251       ---                ---
R2#sh standby brief
Interface   Grp  Pri P State   Active          Standby         Virtual IP
Fa0/0       123  115 P Active  local           10.1.123.253    10.1.123.254
Fa0/1       234  115 P Active  local           1.1.1.3         1.1.1.254
R3#sh stan brief
Fa0/0       123  100 P Standby 10.1.123.252    local           10.1.123.254
Fa0/1       234  100 P Standby 1.1.1.2         local           1.1.1.254
R3#sh ip nat translations
R2
int fa0/1
shut
R2#sh standby brief
Fa0/0       123  65  P Standby 10.1.123.253    local           10.1.123.254
Fa0/1       234  115 P Init    unknown         unknown         1.1.1.254
3#sh stan brief
Fa0/0       123  100 P Active  local           10.1.123.252    10.1.123.254
Fa0/1       234  100 P Active  local           unknown         1.1.1.254
res
Paul
Kind Regards
Paul
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
If I understand your question correctly, if you have equal cost routes, to same destination, via both ISP links, and if CEF is enabled, CEF packet-by-packet load balancing might do the trick.  However, splitting packets from a single flow, is generally a very bad idea.
Better would be to round robin egress flows across both your ISPs.  Best would be to use something like OER/PfR to dynamically load balance egress flows across both you ISPs.
