Cisco EPC3928 router+ WIFI extender antenna
Zathan
Hi guys,
I'm hoping I will explain my issue as accurate as I can.
Basially I do have Cisco EPC 3828 router which is at the ground floor of my house, WIFI signal is quite weak and bedrooms located on 1st floor are barely getting any signal hence I bought this:
https://www.alibaba.com/product-detail/2-4GHz-300Mbps-802-11N-Wireless_60133601703.html?spm=a2700.7724838.2017115.172.3c93b095voBWjL
Idea is simple broadband signal-->router-->wifi antenna located upstairs-->clients
Can someone be so kind and please let me know step-by-step instructions what has to be modified in router setting and how to setup both that antenna will be working as a "wifi reapeter".
I have found this setting: cisco.PNG
 But no matter what I do I can't access WIFI antenna and "tick" this option which seems to be quite relevant for what I'm looking for..
Thank you! :)
Hello
Not sure I understand, its basically requesting you to add the mac- address of the wifi/router into that GUI so that device will become a repeater between your clients and the wifi/router you have downstairs.
Not doubt you need to make some changes on the wifi/router also to accomodate
res
Paul
Kind Regards
Paul
