08-22-2017 09:21 AM - edited 03-05-2019 09:01 AM
Hi folks, I've been always working with an ISP, let's call it A. ISP A give me IP address 208.X.X.182/30, obviously where 208.X.X.181 is my Gateway:
interface TenGigabitEthernet0/0/0
description *** ISP A ***
ip address 208.X.X.182 255.255.255.252
In my ASR1001-X I had this: ip route 0.0.0.0 0.0.0.0 208.X.X.181 and besides I have my own IP addressing (170.X.X.0/22) and everything was working fine.
Last week my company hired a second ISP (let's call it B). ISP B gave me 187.X.X.113/31 and Gateway 187.X.X.112:
interface TenGigabitEthernet0/0/1
description *** ISP B ***
ip address 187.X.X.113 255.255.255.254
So, I changed to this ip route 0.0.0.0 0.0.0.0 187.X.X.112 in the ASR and keep using my own addressing (170.X.X.0/22). Everything keeps working fine but I have a problem with interfaces showing traffic. I expect that all traffic goes through interface TenGigabitEthernet0/0/1 but I'm getting this:
Contencion1001-X#sh interface TenGigabitEthernet0/0/1 | i rate
Queueing strategy: fifo
5 minute output rate 73785000 bits/sec, 51960 packets/sec
and this:
Contencion1001-X#sh interface TenGigabitEthernet0/0/0 | i rate
5 minute input rate 790589000 bits/sec, 80042 packets/sec
my question is: should not interface TenGigabitEthernet0/0/0 shows no traffic at all ???
Solved! Go to Solution.
08-22-2017 09:44 AM
All your traffic is going out the T0/0/1 interface, but the return traffic is coming back through the first ISPF on T0/0/0.
Either that or your second ISP is not advertising your 170.x.x.0/22 address block at all, or both ISPs are advertising your 170.x.x.0 /22 to the Internet and ISP #1 (T0/0/0) has the best return path.
Obviously, if it is the first issue, you need to get that rectified. If it is the second issue you could ask ISP #1 to AS prepend your block to the other ISPs.
Other than that you could possible BGP peer with both ISPs from the ASR1001 and control it yourself.
Hope this helps
08-22-2017 09:44 AM
Hope this helps
08-22-2017 11:19 AM
many thanks!!!
definetly is the second issue, since my second provider is advertising my 170.x.x.0/22 address block. I have planned BGP in the near future but my concern would be: what happens if ISP A goes down ?? the return traffic would comes through T0/0/1 ?????
Thanks.
08-22-2017 12:19 PM
If you decide to BGP peer with both ISPs and your connection to either of them goes down, traffic should just reroute to the other. Since you are doing it all in one router it should be fairly simple to implement.
Appreciate the earlier votes.
08-22-2017 12:30 PM
thanks chrihussey, I understand what you say, but the question is: right now (befor BGP) if ISP A goes down the return traffic would comes through T0/0/1 ????? I mean, would I still have access to internet???
Thanks.
08-22-2017 12:58 PM
If the link to ISP A fails, if they are configured properly (and they should be) they should stop advertising your route to the rest of the Internet. Generally, the route to your netblock from the ISP is based on astatic route to you across the link. If that link fails the route should be withdrawn.
08-22-2017 01:38 PM
ok got it
Thanks!!
