09-01-2009 11:29 AM - edited 03-04-2019 05:54 AM
I have a Cisco 2650XM and a Multitech 820 and I am wondering if any one has any experience getting a VPN up between the two types of routers? Attached is the IPSec setup screen for a multitech.
Any Ideas?
09-03-2009 06:02 AM
Hello Chad,
this is possible if the C2650XM IOS image supports IPSec.
post a sh ver | inc image
important note:
pfs to be noted can have performance impact.
see an example similar here:
Hope to help
Giuseppe
09-03-2009 07:32 AM
The version I have does support IPSec because I have a VPN up between two cisco routers with this version: flash:c2600-jk9s-mz.123-17c.bin
What is the pfs?
Thanks so far
09-03-2009 08:36 PM
Hello Chad,
pfs = perfect forward secrecy improves encryption
follow Pompey's suggestions starting as simple as possible is the best approach.
Hope to help
Giuseppe
09-03-2009 07:31 PM
Where exactly is it failing? Are you getting passed phase 1?
When i run into trouble with VPN's I like to dial down the enc/hash level. I also like to remove any superfluous stuff. Try establishing a 3DES/MD5 SA using a basic key (cisco12345) default timers and no PFS. Don't use FQDN's either until your sure you can establish the SA using just the IP.
