Cisco Integrated Service Router 3825
clevelandwpc
I have a Cisco Integrated Service Router 3825. It has three physical interfaces(GigbitEthernet0/0, GigbitEthernet0/1 and one SFP ), I would like to use three interfaces at the same time as a firewall to build three zones(Inside, DMZ and Internet) each of the three interfaces will be assigned as Inside, DMZ and Internet zones. However it seems I can only use 2 interface as the same time. The SFP can be enabled only  on GigbitEthernet 0/0 port, and the show run only have two interfaces(Gi0/0,Gi0/1). Is there anyway I can add the third interace Gi0/2 into my cisco configration? Following are the results of show version commands. Thanks for your help.
show version:
Cisco IOS Software, 3800 Software (C3825-ADVENTERPRISEK9-M), Version 15.1(4)M12a, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Tue 04-Oct-16 04:18 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T11, RELEASE SOFTWARE (fc1)
supernovarouter3825 uptime is 1 day, 15 hours, 25 minutes
System returned to ROM by reload at 21:20:34 UTC Wed Oct 4 2017
System image file is "flash:c3825-adventerprisek9-mz.151-4.M12a.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 3825 (revision 1.2) with 1011712K/36864K bytes of memory.
Processor board ID FTX1422A0G1
2 Gigabit Ethernet interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
254464K bytes of ATA System CompactFlash (Read/Write)
License Info:
License UDI:
Device# PID SN
*0 CISCO3825 FTX1422A0G1
2 Accepted Solutions
You have to add an interface module for that:
https://www.cisco.com/c/en/us/products/routers/3800-series-integrated-services-routers-isr/relevant-interfaces-and-modules.html#ethernetrouted
But I wouldn't invest any more money in this EOL device.
EDIT: corrected the above link.
If you still want to go with this device:
1) These modules could come quite cheap on ebay.
2) You could use subinterfaces on the internal interfaces and connect your inside and DMZ network to different VLANs on a switch. Not perfect, but better than not having a DMZ.
What about moving to an ASA 5506-X; it's faster than the router and has more security.
7 Replies 7
Great, I will use subinterfaces solution. Thanks again.
Kevin
it's now working ... something happened when pasting the link.
Can you send the link again? The one you sent before dose not work. Thanks again.
