VRRP between Juniper SRX and Cisco
roycemathew
VRRP not forming between SRX and Cisco on MD5/Key-string/Key Chain. Any thoughts?
IOS - c2900-universalk9-mz.SSA.155-3.M1.bin
Junos: 15.1X49-D100.6
JUNOS Software Release [15.1X49-D100.6]
no key chain VRRP
key 0
key-string TEST
interface GigabitEthernet0/0.334
!vrrp 1 authentication md5 key-chain VRRP
!vrrp 1 authentication md5 key-string TEST
VRRP v3 doesnt support authentication.
Georg Pauwen
MD5 uses port 51 for the authentication header, make sure that port is not blocked somewhere. Also, make sure you are running the same VVRP version on both the Cisco and the SRX.
Can you post the Juniper VRRP config ?
