cisco ios 2811 issue
mouazyusuf
I bought cisco router 2811 from ebay and when start it  I cannot start the conf mode it stuck in rommon mode
what do I do to start config mode?
"c2811 platform with 524288 Kbytes of main memory
Main memory is configured to 64 bit mode with ECC enabled
Upgrade ROMMON initialized
Compact Flash:not present
rommon 1 > reset
Main memory is configured to 64 bit mode with ECC enabled"
problem is Compact Flash:not present no flash so no IOS.
check the front panel of the 2811 you will see compact flash on the left, I hope you have compact flash and just needs reseating!
Richard.
Richard.
