Cisco IOS DNS Lookup order
pingduck
I am trying to understand the DNS lookup order on the router.
Let's say I have the following config:
ip host aaa.com 1.1.1.1
ip name-server 8.8.8.8
when I try to ping:
#ping aaa.com
Translating "aaa.com"...domain server (8.8.8.8)
Sending 5, 100-byte ICMP Echos to 1.1.1.1, timeout is 2 seconds:
Clearly, aaa.com is not 1.1.1.1. I see my config overrides Google's 8.8.8.8. This makes sense. But what bothers me is that it still tries to resolve through 8.8.8.8. If I put in a non-existing DNS server:
no ip name-server 8.8.8.8
ip name-server 25.25.25.25
It clearly still try to resolve
#ping aaa.com
Translating "aaa.com"...domain server (25.25.25.25) <<---- long wait here
Success rate is 100 percent (5/5), round-trip min/avg/max = 24/29/36 ms
What can I do to prevent that DNS lookup from happening and slowing down my local DNS resolution?
7 Replies 7
balaji.bandi
Cisco Router can Act as DNS Server for your Client. But most of FQDN it uses DNS resolution.
my view from FQDN lookup always uses the name server. but i belive local user want to access local server.
they should be like example :
ip host aaa.local 1.1.1.1
if you want to IOS Device act as DNS Server follow below document :
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipaddr_dns/configuration/15-sy/dns-15-sy-book/Configuring-DNS.pdf
BB
What I want to do is use external server for DNS lookup. The IOS router also acts as a DNS server and I want it to resolve some local DNS names. The aaa.com config is just an example to illustrate the problem. I want the IOS DNS server to simply return the static IP without performing another DNS query because it takes time especially when DNS serve is not reachable.
Hello
no ip domain-lookup
Kind Regards
Paul
(removed due to duplicate)
Seth Beauchamp
What device and software version are you trying this on? It may depend on platform/software. Trying it on a CSR1000v 3.13.5 I get a different result than you are getting.
R25#ping aaa.com
If i remove "ip host aaa.com 1.1.1.1"....
R25#ping aaa.com
Thanks. Looks like it maybe OS specific. I'm running 15.8(3)M0a (Classic IOS, not IOS-XE). Bummer!
i was thought the same due to old IOS.
BB
