Cisco IOS NAT Route Maps
Steven Mills
I am having some trouble using route-maps for NAT, I have simplified it as much as possible and I am still unable to get traffic to match.
Usng an ACL with the following configuration works fine:
ip nat pool pool-web01 150.100.1.1 150.100.1.1 netmask 255.255.255.248
ip nat inside source list acl-web01-out pool pool-web01 overload
ip access-list extended acl-web01-out
permit ip host 172.16.1.1 any
However using the same ACL in a route-map fails:
ip nat inside source route-map rm-web01-out pool pool-web01 overload
route-map rm-web01-out permit 10
match ip address acl-web01-out
Can anyone explain what the issue is here?
Thanks.
6 Replies 6
Roman Rodichev
Level 7
Level 7
Try numbered ACL, I've had issues with NAT route-maps and named ACLs.
I have a continus ping going, still no matches with a numbered ACL in the route-map.
router#show route-map rm-web01-out
route-map rm-web01-out, permit, sequence 10
  Match clauses:
    ip address (access-lists): 177
  Set clauses:
  Policy routing matches: 0 packets, 0 bytes
or on the ACL
Extended IP access list 177
    10 permit ip host 172.16.1.1 any
I don't think you'll see matches in route maps and ACLs. There are a bunch of various situations in IOS where ACL and ROUTE MAP matches will not be tracked.
Jeff Van Houten
Level 5
Level 5
Don't you need a set statement after the match address?
Neeraj Arora
Level 3
Level 3
Steven,
Most probably you are hitting an IOS bug because configuration wise there is no problem in your config.
It does happen sometimes that same NAT statement does not work with a Standard ACL whereas it will work fine with an Extended ACL, or it will not work with Route-map but will work fine with an ACL
Any specific reason you want to use Route-map in NAT overload?
If this is a major requirement, then check to see if you can for an IOS upgrade on the router
Hope it helps
Neeraj
Neeraj,
I have considered that it could be an IOS bug however I am running the latest 12.4 code (124-24.T5) and I am sure I have seen similar problems with routers running 15.x code as well.
I need to use a route-map becasue I have a second internet connection and I want to use also match an interface in the route-map. I think I may raise a TAC case for this one.
Thanks for your help.
Steve
