06-06-2021 12:10 PM
Hi Team,
Good Evening!
i am not able to upgrade the IOS in 4451, i have completed the below 4 steps.
please advise?
Image attached for reference.
Step1 HQ#dir usb0:
Step2 HQ#copy usb0: isr4400-universalk9.16.06.09.SPA.bin
up
Step3 HQ#dir flash:
Step4 HQ#verify bootflash:/ isr4400-universalk9.16.06.09.SPA.binisr4400-universalk9.16.06.09.SPA.bin
Step5 HQ#upgrade rom-monitor filename bootflash:/isr4400-universalk9.16.06.09.SPA.binisr4400-universalk9.16.06.09.SPA.bin R0
06-06-2021 12:28 PM
Are you able to read the file in USB ? ( make sure USB is FAT 32 formatted, and nice to have low capacity like 8GB)
can you post dir USB content also?
What are you trying to do ROMMON Upgrade ?
what is the current version - post-show version
here is ROMMON Upgrade procedure :
https://www.cisco.com/c/en/us/td/docs/routers/access/4400/cpld/isr4400_hwfp.html#pgfId-1077103
here is the release notes and IOS XE Upgrade :
06-07-2021 05:03 AM
>>> upgrade rom-monitor filename bootflash:/isr4400-uni .... <<<
the command is for upgrading the rommon (let's call it the BIOS) but the file you are using is the IOS (Operating System)
You've either got the wrong file or are using the wrong command
06-07-2021 07:43 AM
The router reboots to do the ROMMON upgrade, so the BIOS does not have the ability to access the USB drive. My experience has been that you have to copy the ROMMON upgrade file to the bootflash, and use that location when you issue the "upgrade rom-monitor" command.
