Cisco IOS XE routing issue
childebrecht
Good afternoon.   I am in the process of upgrading from a Cisco 892F to a Cisco 1111 IOS XE router and am having an issue routing traffic from the LAN network to the WAN interface utilizing a zone based firewall setup.  When I am logged into the router I can ping/etc to the outside internet and when I am on a device connected to the LAN interface I can ping the Vlan gateway of 192.168.0.1 configured in my router.  I am just not able to transition from that to the outside interface/network.  Can someone please assist in what I am doing incorrectly.  Thanks.
Hello
Your ZBFW is very convoluted however from what i can see is your inside-outside zone isn't allowing for icmp, http or dns.
try the following:
class-map type inspect match-any sdm-cls-access
match protocol icmp
match protocol dns
match protocol http
Kind Regards
Paul
5 Replies 5
the first thing I noticed is that your access list 197 is empty. Add the line marked in bold to that access list:
ip access-list extended 197
--> 10 permit 192.168.0.0 0.0.0.255 any
Thank you.  I went ahead and added but it did not resolve.   It is a strange problem and being new to both IOS XE and the zone based firewall I am sure it is just a misconfiguration somewhere.   From my LAN device, I can ping the 192.168.0.1 gateway in the router and also the static IP address on the GigabitEthernet0/0/0 (WAN interface) but can not get to the gateway of the WAN interface.
So it's definitely something with my zones or firewall rules. If I remove
the interfaces from the zone-member security out/in zones then I pass
traffic just fine. I am going to keep digging.
Hello
try the following:
match protocol icmp
match protocol dns
match protocol http
Kind Regards
Paul
Thank you for the response. I will test this when I am back in office tomorrow. A lot of the current config is probably irrelevant now. It was converted over from a previous router that was in service for years. Once I get the traffic functioning correctly then I can start going back through and cleaning up the other rules.
