Cisco ISR 4431 IOS Upgrade
mikeriley
Having issues upgrading Cisco ISR 331 router from IOS 16..06.04 to 16.12.04. I have moved the file to the local flash and have attempted to run the only two upgrade commands I know:
boot system flash:/filename
boot system flash bootflash:/filename
I have downloaded the 16.12.04 file from Cisco and verified is a maintenance deployment. I have a small screen capture of the error. See the attached.
marce1000
 - Have an md5sum verification check of the image before and after downloading on the isr (the isr may support this command too) and or as a sanity check, try another (preferably more recent) from the cisco download site.
 M.
marce1000
 - You may also find this document useful : https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/sec_usr_cfg/configuration/xe-3s/sec-usr-cfg-xe-3s-book/sec-image-verifctn.pdf
 M.
Leo Laohoo
@mikeriley wrote:
%ERROR% Booting an incompatible image for this platform
Failed to boot file bootflash:isr4400v2-universalk9.16.12.04.SPA.bin
The IOS file is meant for a "v2" and the appliance is not.
