Cisco IOS XR platform command to track commands executed by users
Hi all,
Thanks in advance.
I am using both XE and XR IOS routers. when I executed below commands in XE, I am able to track commands executed by users through syslog.  But the same is not working in XR IOS router.  Please guide me with equivalent commands for XR.
#archive
#log config
#logging enable
#notify syslog
Or else you can suggest me some alternate options to keep a track of executed commands in router.
Vignesh
johnlloyd_13
Level 9
Level 9
hi,
it's easier to track/check if you're using a RADIUS or TACACS for command accouting.
you can use the combination of show configuration commit list and show configuration rollback changes <COMMIT ID> commands.
see example below:
#show configuration commit list
Thu Apr 29 05:10:07.665 UTC
SNo. Label/ID              User      Line                Client      Time Stamp
1    1000000156            john     vty1:node0_RP0_CPU  CLI         Thu Apr 29 03:36:09 2021
2    1000000155            john     vty1:node0_RP0_CPU  Rollback    Thu Apr 29 03:31:56 2021
3    1000000154            john     vty0:node0_RP0_CPU  CLI         Tue Apr 27 07:43:13 2021
4    1000000153            john     vty0:node0_RP0_CPU  CLI         Sat Apr 24 14:15:54 2021
#show configuration rollback changes ?
  last        Changes for rolling back last <n> commits
  to          Changes up to (and including) a specific commit
  to-exclude  Changes up to (and excluding) a specific commit
  1000000154  Commit ID
  1000000153  Commit ID
  1000000152  Commit ID
  1000000151  Commit ID
  1000000150  Commit ID
  1000000149  Commit ID
#show configuration rollback changes 1000000154
Thu Apr 29 03:28:48.896 UTC
Building configuration...
!! IOS XR Configuration 7.2.2
no ssh server dscp 24
johnlloyd_13
Level 9
Level 9
hi,
see example below:
Thanks John
