Create a route-map in FDM
in FMC using flex config there is an example and it works
video
PRB-HR 192.168.1.2 MY-GW-1 192.168.100.1
PRB-IT 192.168.5.2 MY-GW-2 192.168.200.1
route-map $ Route-MAP-Name resolution 10
set ip next-hop verify-availability $ GW-1 1 track 1
set ip next-hop verify-availability $ GW-2 2 track 2
route-map $ resolution Route-MAP-Name 20
set ip next-hop verify-availability $ GW-2 1 track 1
set ip next-hop verify-availability $ GW-1 2 track 2
interface Port-channel 4.3
policy-route $ Route-MAP-Name
interface Port-channel 4.6
Now
I need to configure everything through FDM
can't create route map in FDM
please write how to create a route map in FDM
or give a customization example
Google could not find examples
This Video show how to configure PBR using FMC FlexConfig. Correction: During Flex-Configuration, instead of applying Route-map on Ethernet 1/1 & Ethernet 1/3 which is outside. It should be applyed on Ethernet 1/2 (Inside Interface). Linkedin: https://www.linkedin.com/in/nandakumar80/ For Latest ...
This is not yet possible through native FDM configuration. As with FMC, you have to go through FlexConfig which is quite similar to what you have seen in the FMC-documentation:
https://www.cisco.com/c/en/us/td/docs/security/firepower/660/fdm/fptd-fdm-config-guide-660/fptd-fdm-advanced.html#task_36ECF548DADB4200A448CC163B03ADB0
is it possible to do this with FDM?
found it
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvb19682
created in object acl and route-map
access-list acl-isp2 standard permit host 192.168.1.2
route-map pbr-isp2 permit 10
match ip address acl-isp2
match interface vlan-id-3
set ip next-hop 31.31.31.31
Where
vlan-id-3 sub-interfce (192.168.1.0/24)
31.31.31.31 - second isp2
everyone goes through isp1 and host 192.168.1.2 must go through isp2
does not work, which is not correct in such a configuration?
do i need to use flex object and how to do it?
