Cisco IOS Zone-based Firewall issue
Pradeep H A
Can anybody clarify if the line "received 25 packets out of order" in the show policy-map type inspect output correspond to the log about session being dropped due to invalid Seq# ? because I am not seeing packet drops anywhere else in our network... what might be the possible issue?
Thanks a lot in advance
Router#show policy-map type inspect zone-pair store-to-wan-policy
policy exists on zp store-to-wan-policy
Zone-pair: store-to-wan-policy
Service-policy inspect : store-to-wan-policy
   Class-map: store-to-wan (match-all)
     Match: access-group name store2wan
     Match: class-map match-any protocols
       Match: protocol pptp
         0 packets, 0 bytes
         30 second rate 0 bps
       Match: protocol ftp
         0 packets, 0 bytes
       Match: protocol dns
         0 packets, 0 bytes
       Match: protocol ldap
         0 packets, 0 bytes
       Match: protocol snmp
          0 packets, 0 bytes
       Match: protocol icmp
         0 packets, 0 bytes
       Match: protocol tcp
         0 packets, 0 bytes
       Match: protocol udp
         0 packets, 0 bytes
   Inspect
       Packet inspection statistics [process switch:fast switch]
       tcp packets: [344526:285947185]
       udp packets: [758583:4725011]
       icmp packets: [1:113268]
       Session creations since subsystem startup or last reset 5483319
       Current session counts (estab/half-open/terminating) [27:0:0]
       Maxever session counts (estab/half-open/terminating) [461:82:42]
       Last session created 00:00:04
       Last statistic reset never
       Last session creation rate 79
       Maxever session creation rate 1528
       Last half-open session total 0
       TCP reassembly statistics
       received 25 packets out-of-order; dropped 0
       peak memory usage 2 KB; current usage: 0 KB
       peak queue length 1
   Class-map: class-default (match-any)
     Match: any
     Drop
       236974 packets, 37544695 bytes
Router#sh log | i store-to-wan-policy
Dec 6 04:30:35.598 UTC: %FW-6-DROP_PKT: Dropping udp session 10.54.12.86:137 198.94.220.196:137 on zone-pair store-to-wan-policy class class-default due to DROP action found in policy-map with ip ident 0
Dec 6 04:42:57.729 UTC: %FW-6-DROP_PKT: Dropping udp session 10.54.12.86:137 198.94.220.196:137 on zone-pair store-to-wan-policy class class-default due to DROP action found in policy-map with ip ident 0
Dec 6 04:43:28.661 UTC: %FW-6-DROP_PKT: Dropping tcp session 10.54.12.151:53810 198.94.69.97:53 on zone-pair store-to-wan-policy class store-to-wan due to Invalid Seq# with ip ident 0
Router#sh clock
05:42:25.806 UTC Thu Dec 6 2012
0 Replies 0
