Cisco ospf syslog messages
Hello Community,
Can someone please tell me if the following messages are flagged should a ospf %OSPF-5-ADJCHG occur?
badVersion 1
areaMismatch 2
unknownNbmaNbr 3
unknownVirtualNbr 4
authTypeMismatch 5
authFailure 6
netMaskMismatch 7
helloIntervalMismatch 8
deadIntervalMismatch 9
optionMismatch 10
mtuMismatch 11
duplicateRouterId 12
noError 13
Cheers
Carlton
if we change hello-interval on one side then the adjency will go down but we won't receive any message indicating this is a mistmatched hello parameter which is the cause.
Regards.
Alain
6 Replies 6
mahmoodmkl
Level 7
Level 7
The adjacency will not occur due to below reasons.
1.area ID mismatch.
2.subnet mismatch.
3.autentication mismatch.
4.hello/dead intervals mismatch.
5.mtu mismatch.
mahmood,
Thanks for responding. I understand that an adjacency won't occur for the reasons you mentioned. My question is will any of those reason appear in a syslog message if for example an existing adjacency disappeared for any of those reasons?
Cheers
no it will only tell you that it went from FULL to Down but  in certain cases you'll receive other OSPF syslog messages
indicating the problem
for example let's change the area on one side:
%OSPF-5-ADJCHG: Process 1, Nbr 10.0.0.2 on FastEthernet0/0 from FULL to DOWN, Neighbor Down: Interface down or detached
%OSPF-6-AREACHG: 10.0.0.1/32 changed from area 0 to area 1
%OSPF-4-ERRRCV: Received invalid packet: mismatch area ID, from backbone area must be virtual-link but not found from 10.0.0.2, FastEthernet0/0
Regards.
Alain
mahmoodmkl
Level 7
Level 7
afaik they appear on the console
Regards.
Alain
Cadet,
This is exactly what I thought.
Cheers mate.
