Cisco IPSec LAN-TO-LAN
mediaos718
I have an IPsec LAN-to-LAN tunnel between a Cisco router and a Palo Alto FW. The tunnel remains UP-ACTIVE if there is interesting traffic - The tunnels goes down if there is no interesting traffic. The problem I am having is that I cannot bring the tunnel up from the Cisco side - If I initiate a ping from the Cisco side to go through the VPN, this will not bring the tunnel up. If I initiate the ping from the Palo Alto side then the tunnel comes up.
How do I have to configure the Cisco router to keep the tunnerl UP-ACTIVE at all time?
How can I bring the tunnel up from the Cisco router side?
rypto isakmp policy 10
encr aes 256
authentication pre-share
group 5
lifetime 28400
crypto isakmp key MYVPN! address x.x.x.x
crypto isakmp invalid-spi-recovery
crypto isakmp keepalive 10 periodic
crypto ipsec transform-set MYSET esp-aes 256 esp-sha-hmac
mode transport
crypto map MYMAP 10 ipsec-isakmp
set peer x.x.x.x
set security-association lifetime kilobytes 65000
set transform-set MYSET
match address Dublin_Subnet
ip access-list extended Dublin_Subnet
permit ip host 192.168.100.1 host 10.117.0.160 log
16 Replies 16
All, this has been resolved. The Palo was using "set pfs group5" - I added this config and the tunnel comes up and stays up.
Thanks for posting back to the forum and telling us that the issue is resolved and that the problem was a mismatch in configuration of pfs. +5 for solving your own problem. It is a very good thing when someone asks the forum for help with a problem and then is able to find the solution themselves. Congratulations.
Rick
Rick
