Cisco IR829 WLAN RED LED Blink
Hello All,
I have Cisco IR829. I can see RED LED flashing on WLAN interface, whereas I am not using WLAN.
I am using this router for routing purpose, not for Wireless/WLAN.
Do you have any idea, why it is flashing and how we can resolve this issue.
I have many router with the same model/OS/Config, but none of them reflex this issue.
6 Replies 6
what is the output of:
IR829#service-module wlan-ap 0 status
Dear Georg Pauwen,
Please find the output below.
TRN-5105-T-CCU-01#service-module wlan-ap 0 status
Service Module is Cisco wlan-ap0
Service Module supports session via TTY line 4
Service Module is failed
Service Module reset on error is disabled
Service Module heartbeat-reset is enabled
Service Module is in fail open
Service Module status is not available
Rajinder,
I have been dealing with the same problem for quite a while now. I have been working with some of the folks from Cisco to determine the cause and a solution for a while now but at this time we have not been able to isolate the issue. Please do update this thread if you have had any further developments in terms of a solution.
what happens if you configure the interface with an IP address and connect ? This just to make sure that it is not a hardware fault, and the module is actually functioning.
interface wlan-ap0
ip address 172.16.1.1 255.255.255.0
829#service-module wlan-ap 0 session
Make sure your VTY lines are configured wih:
transport input all
newnovice
Hello~
Encounter the same problem, the wlan led truned flashing red, and the service-module wlan-ap 0 status also report some failed as follows, is this hardware or software problem? We don't use wlan functionality and 4g routing working well.
Hello
Disable the wlan card on the rtr-
conf t
inter wlan-ap 0
shut
Kind Regards
Paul
