cisco ISR 11000 Stuck after image validated Please HELP!
IT SOLUTIONS
Rom image verified correctly
System Bootstrap, Version 16.9(1r), RELEASE SOFTWARE
Copyright (c) 1994-2018 by cisco Systems, Inc.
Current image running: Boot ROM0
Last reset cause: PowerOn
C1111-4P platform with 4194304 Kbytes of main memory
no valid BOOT image found
Final autoboot attempt from default boot device...
Located throughput_monitor_params
Unsupported package header version (-1347440721)
Located c1100-universalk9_ias.16.09.02.SPA.bin
Package header rev 3 structure detected
IsoSize = 416391168
Calculating SHA-1 hash...Validate package: SHA-1 hash:
calculated 3247276D:E1CAC3CB:E6327294:86F39D2D:155D7289
expected 3247276D:E1CAC3CB:E6327294:86F39D2D:155D7289
RSA Signed RELEASE Image Signature Verification Successful
Image validated
16 Replies 16
@fabiofariasff wrote:
System Bootstrap, Version 16.3(2r), RELEASE SOFTWARE
ROMMON version 16.3(2r) is not compatible with anything past 16.3.X.
Upgrade the ROMMON to 17.3(1r) and the router should be able to boot up to 17.9.X.X.
WARNING
Do not perform a direct upgrade, from 17.6.X (and earlier) to 17.12.X (and later) or else the router will go into a boot-(silent) crash-loop.
Cisco ISR & ASR 1k Routers: IOS-XE/Firmware Upgrade (Install Mode)
jmartinez20
Have you tried booting off from Packages.conf
basically boot off any image (bin) and then copy new bin image to router and then run command request platform software package expand file >>> this will create the(packages file)
Don't forget to set new boot variable pointing to the pakcages. > packages.conf
Installing Subpackages from a Consolidated Package on a Flash Drive
The steps for installing subpackages from a consolidated package on a USB flash drive are similar to those described in the Installing Subpackages from a Consolidated Package section.
Procedure
Step 1
show version
Step 2
dir usbn:
Step 3
show platform
Step 4
mkdir bootflash:URL-to-directory-name
Step 5
request platform software package expand fileusbn: package-name to URL-to-directory-name
Step 6
reload
Step 7
boot URL-to-directory-name/packages.conf
Step 8
show version installed
https://www.cisco.com/c/en/us/td/docs/routers/access/1100/software/configuration/xe-16-7/cisco_1100_series_swcfg_xe_16_7_x/cisco_1100_series_swcfg_chapter_0111.html
