Cisco ISR 1111-8P MPLS Support Bandwidth
Hello! Everyone.
I have a Query.
I want to use Cisco ISR 1111-8P as an aggregation router. Is it support 1040Mbps MPLS Circuit?
pigallo
ISR1k is generally used as CPE, so basically as an access device.
Although MPLS is supported, throughput may vary in function of which services you should run within your architecture.
