04-11-2019 07:55 AM
Folks,
I am looking for some assistance in configuring Cisco ISR router 1111, We recently purchased this router to replace our old dlink router so wondering how to set it up and what configuration needs to go on Cisco ISR 1111 ?? also we have 2 APs that needs to be connected.
PS: the router connects to DSL modem
thanks
04-11-2019 09:22 AM
Welcome @network1215,
Me and everyone in the Cisco community is willing to help you.
We need to make your question more specific though.
In which part of the configuration process you are stuck?
This will give us a better idea how we can start helping you.
04-16-2019 05:57 PM
Hi Hector,
appreciate your response, I found below link which is exactly what I was looking for, that explains how you can setup the router from the scratch.
https://community.cisco.com/t5/routing/isr-1100-no-internet-access/td-p/3690840
04-17-2019 08:31 AM
I agree with Hector in saying Welcome to the Community. I am glad to know that you have found a document in the community which explains what you need. This community is an excellent place to ask questions and to learn about networking. As you have discovered it has resources to answer many questions. I hope to see you continue to be active in the community.
Rick
04-11-2019 12:45 PM
You may want to seek and contract a professional service if you want a complete solution.
For self-starter, you can read several sources to equip yourself the necessary to knowledge to build your LAN.
Here is a link about the design, https://www.cisco.com/c/dam/en/us/td/docs/solutions/CVD/Campus/CVD-Campus-LAN-WLAN-Design-Guide-2018JAN.pdf. I think your design should be an access layer, page 11.
Here is a link to get the configuration guide, https://www.cisco.com/c/en/us/td/docs/routers/access/1100/software/configuration/xe-16-7/cisco_1100_series_swcfg_xe_16_7_x.pdf.
Typically, you configure your router with basic network and port configuration as well as configuring DHCP, WLAN, and security.
