Cisco ISR 1121 router
ksch
I'm about to purchase a 1121 router. I want to make sure it can support a L2VPN but can't find any answer on the specs sheets. Anyone know if it can support a L2VPN?
Hi @ksch
  It does not. With proper license it can do IPsec VPN, DMVPN, FlexVPN, GETVPN.
https://www.cisco.com/c/en/us/products/collateral/routers/1000-series-integrated-services-routers-isr/datasheet-c78-739512.html
Giuseppe Larosa
Hello @ksch ,
according to Feature Navigator L2TPv3 is supported on 1100 series with appropriate license like appx , appx + security
https://cfnng.cisco.com/browse/routing/products
L2TPv3 allows only to build point to point L2 VPN services no support for any to any .
An L2TPv3 tunnel can be protected by an IPsec tunnel for security reasons.
Hope to help
Giuseppe
